[Qgis-user] Spatialite : problems with spatial views
    Samy Mezani
    samy.mezani at wanadoo.fr
    Fri Feb 22 04:07:38 PST 2013
le 22/02/2013 11:57, Alexandre Neto a écrit:
> There, I found out that, for correctly open a spatialite spatial view in
> QGIS, I would need to have a column named ROWID.
Thanks Alexandre,
My problems are partially resolved with your workaround :
1. The spatial index still blocks the load of geometry in QGis. I had to
remove it before.
2. After adding a rowid, the attributes window show all the values of
features but I have to wait 70s for 44 features and CPU used at 100%.
3. After adding a rowid, all labels are created.
So Qspatialite should integrate a creation of a rowid to load correctly
a spatial view in Qgis.
DB Manager continue to not load the geometry even if a rowid is created.
Thanks a lot.
Samy
