[Qgis-user] How to use Sextante Pyculator correctly?
    Victor Olaya
    volayaf at gmail.com
    Sat Jan  5 09:06:33 PST 2013
oooops, my fault.
I forgot that the current development version depends on some new
things in qgis 1.9
You must run it on qgis-dev
Hope this helps
Victor
2013/1/5 Anita Graser <anitagraser at gmx.at>:
> On Sat, Jan 5, 2013 at 4:31 PM, Victor Olaya <volayaf at gmail.com> wrote:
>> While I think about the best way of doing it, here[1] you can download
>> a zip file with the latest SEXTANTE code. I will be updating that link
>> regularly, but I will try to see how to make i
> Thanks Victor,
> I got the zip and replaced my Sextante folder with it but QGIS starts
> with the following error:
> Couldn't load plugin 'sextante' from ['/usr/share/qgis/python',
> '/home/agraser/.qgis//python', '/home/agraser/.qgis//python/plugins',
> '/usr/share/qgis/python/plugins',
> '/usr/local/lib/python2.7/dist-packages/pyspatialite-2.6.1-py2.7-linux-x86_64.egg',
> '/usr/local/lib/python2.7/dist-packages/pyprocessing-0.1.3.12-py2.7.egg',
> '/usr/local/lib/python2.7/dist-packages/twitter-1.8.0-py2.7.egg',
> '/usr/local/lib/python2.7/dist-packages/tweepy-1.9-py2.7.egg',
> '/usr/lib/python2.7', '/usr/lib/python2.7/plat-linux2',
> '/usr/lib/python2.7/lib-tk', '/usr/lib/python2.7/lib-old',
> '/usr/lib/python2.7/lib-dynload',
> '/usr/local/lib/python2.7/dist-packages',
> '/usr/lib/python2.7/dist-packages',
> '/usr/lib/python2.7/dist-packages/PIL',
> '/usr/lib/python2.7/dist-packages/gst-0.10',
> '/usr/lib/python2.7/dist-packages/gtk-2.0',
> '/usr/lib/pymodules/python2.7',
> '/usr/lib/pymodules/python2.7/libubuntuone',
> '/usr/lib/python2.7/dist-packages/ubuntu-sso-client',
> '/usr/lib/python2.7/dist-packages/ubuntuone-client',
> '/usr/lib/python2.7/dist-packages/ubuntuone-control-panel',
> '/usr/lib/python2.7/dist-packages/ubuntuone-couch',
> '/usr/lib/python2.7/dist-packages/ubuntuone-installer',
> '/usr/lib/python2.7/dist-packages/ubuntuone-storage-protocol',
> '/usr/lib/python2.7/dist-packages/wx-2.8-gtk2-unicode',
> '~/.qgis/python', '.',
> '/home/agraser/.qgis/python/plugins/mmqgis/forms']
> Traceback (most recent call last):
>   File "/usr/lib/python2.7/dist-packages/qgis/utils.py", line 143, in loadPlugin
>     __import__(packageName)
>   File "/usr/lib/python2.7/dist-packages/qgis/utils.py", line 309, in _import
>     mod = _builtin_import(name, globals, locals, fromlist, level)
>   File "/home/agraser/.qgis//python/plugins/sextante/__init__.py", line 20, in
>     from sextante.core.Sextante import runalg, runandload, alghelp,
> alglist, algoptions, load, loadFromAlg, extent, getObjectFromName,
> getObjectFromUri
>   File "/home/agraser/.qgis//python/plugins/sextante/core/Sextante.py",
> line 41, in
>     from sextante.modeler.ModelerAlgorithmProvider import
>   File "/home/agraser/.qgis//python/plugins/sextante/modeler/ModelerAlgorithmProvider.py",
> line 34, in
>     from sextante.modeler.EditModelAction import EditModelAction
>   File "/home/agraser/.qgis//python/plugins/sextante/modeler/EditModelAction.py",
> line 28, in
>     from sextante.modeler.ModelerDialog import ModelerDialog
>   File "/home/agraser/.qgis//python/plugins/sextante/modeler/ModelerDialog.py",
> line 48, in
>     from sextante.ui.ui_DlgModeler import Ui_DlgModeler
>   File "/home/agraser/.qgis//python/plugins/sextante/ui/ui_DlgModeler.py",
> line 93, in
>     from qgis.gui import QgsFilterLineEdit
> ImportError: cannot import name QgsFilterLineEdit
> Python version:
> 2.7.2+ (default, Jul 20 2012, 22:32:25)
> [GCC 4.6.1]
> QGIS version:
> 1.8.0-Lisboa Lisboa, exported
> Python path: ['/usr/share/qgis/python', '/home/agraser/.qgis//python',
