[Qgis-user] How to use Sextante Pyculator correctly?
    Anita Graser
    anitagraser at gmx.at
    Sat Jan  5 12:52:06 PST 2013
Thanks Victor,
I wrote a tiny script to do it. Faster than setting up a build environment :)
Best wishes,
Anita
On Sat, Jan 5, 2013 at 6:06 PM, Victor Olaya <volayaf at gmail.com> wrote:
> oooops, my fault.
> I forgot that the current development version depends on some new
> things in qgis 1.9
> You must run it on qgis-dev
> Hope this helps
> Victor
> 2013/1/5 Anita Graser <anitagraser at gmx.at>:
>> On Sat, Jan 5, 2013 at 4:31 PM, Victor Olaya <volayaf at gmail.com> wrote:
>>> While I think about the best way of doing it, here[1] you can download
>>> a zip file with the latest SEXTANTE code. I will be updating that link
>>> regularly, but I will try to see how to make i
>> Thanks Victor,
>> I got the zip and replaced my Sextante folder with it but QGIS starts
>> with the following error:
>> Couldn't load plugin 'sextante' from ['/usr/share/qgis/python',
>> '/home/agraser/.qgis//python', '/home/agraser/.qgis//python/plugins',
>> '/usr/share/qgis/python/plugins',
>> '/usr/local/lib/python2.7/dist-packages/pyspatialite-2.6.1-py2.7-linux-x86_64.egg',
>> '/usr/local/lib/python2.7/dist-packages/pyprocessing-0.1.3.12-py2.7.egg',
>> '/usr/local/lib/python2.7/dist-packages/twitter-1.8.0-py2.7.egg',
>> '/usr/local/lib/python2.7/dist-packages/tweepy-1.9-py2.7.egg',
>> '/usr/lib/python2.7', '/usr/lib/python2.7/plat-linux2',
>> '/usr/lib/python2.7/lib-tk', '/usr/lib/python2.7/lib-old',
>> '/usr/lib/python2.7/lib-dynload',
>> '/usr/local/lib/python2.7/dist-packages',
>> '/usr/lib/python2.7/dist-packages',
>> '/usr/lib/python2.7/dist-packages/PIL',
>> '/usr/lib/python2.7/dist-packages/gst-0.10',
>> '/usr/lib/python2.7/dist-packages/gtk-2.0',
>> '/usr/lib/pymodules/python2.7',
>> '/usr/lib/pymodules/python2.7/libubuntuone',
>> '/usr/lib/python2.7/dist-packages/ubuntu-sso-client',
>> '/usr/lib/python2.7/dist-packages/ubuntuone-client',
>> '/usr/lib/python2.7/dist-packages/ubuntuone-control-panel',
>> '/usr/lib/python2.7/dist-packages/ubuntuone-couch',
>> '/usr/lib/python2.7/dist-packages/ubuntuone-installer',
>> '/usr/lib/python2.7/dist-packages/ubuntuone-storage-protocol',
>> '/usr/lib/python2.7/dist-packages/wx-2.8-gtk2-unicode',
>> '~/.qgis/python', '.',
>> '/home/agraser/.qgis/python/plugins/mmqgis/forms']
>> Traceback (most recent call last):
>>   File "/usr/lib/python2.7/dist-packages/qgis/utils.py", line 143, in loadPlugin
>>     __import__(packageName)
>>   File "/usr/lib/python2.7/dist-packages/qgis/utils.py", line 309, in _import
>>     mod = _builtin_import(name, globals, locals, fromlist, level)
>>   File "/home/agraser/.qgis//python/plugins/sextante/__init__.py", line 20, in
>>     from sextante.core.Sextante import runalg, runandload, alghelp,
>> alglist, algoptions, load, loadFromAlg, extent, getObjectFromName,
>> getObjectFromUri
>>   File "/home/agraser/.qgis//python/plugins/sextante/core/Sextante.py",
>> line 41, in
>>     from sextante.modeler.ModelerAlgorithmProvider import
>>   File "/home/agraser/.qgis//python/plugins/sextante/modeler/ModelerAlgorithmProvider.py",
>> line 34, in
>>     from sextante.modeler.EditModelAction import EditModelAction
>>   File "/home/agraser/.qgis//python/plugins/sextante/modeler/EditModelAction.py",
>> line 28, in
>>     from sextante.modeler.ModelerDialog import ModelerDialog
>>   File "/home/agraser/.qgis//python/plugins/sextante/modeler/ModelerDialog.py",
>> line 48, in
>>     from sextante.ui.ui_DlgModeler import Ui_DlgModeler
>>   File "/home/agraser/.qgis//python/plugins/sextante/ui/ui_DlgModeler.py",
>> line 93, in
>>     from qgis.gui import QgsFilterLineEdit
>> ImportError: cannot import name QgsFilterLineEdit
>> Python version:
>> 2.7.2+ (default, Jul 20 2012, 22:32:25)
>> [GCC 4.6.1]
>> QGIS version:
>> 1.8.0-Lisboa Lisboa, exported
>> Python path: ['/usr/share/qgis/python', '/home/agraser/.qgis//python',
