[Qgis-user] Modify Shp File
Werner Macho
werner.macho at gmail.com
Mon Jan 7 11:44:51 PST 2013
Werner,
Appreciate the quick response!
Currently I opened up the shp file with the Add Vector layer option. I
don't see how to edit from here or the nodes. Am I wrong track?
Right now I have the dbf file with the states and counties I want
included. Now just a matter of how to get proper shp and shx files.
That is why they shouldn't give this job to an accountant! LOL
Hi!
Not sure if i understand you .. you have a Shapefile (which usually
consists of 3-6 different files including .shp .shx .dbf .prj and so on) -
but you only add the .shp with add vector layer ..
Then everything should already be inside QGIS ..
The rest is just a matter of editing, selecting, deleting ..
If you only have the shp file - then someone fooled you ;)
http://en.wikipedia.org/wiki/Shapefile
good luck
kind regards
Werner
P.S: lets stick to the mailing list -- just for the logs
On Mon, Jan 7, 2013 at 8:19 PM, Werner Macho <werner.macho at gmail.com> wrote:
> On 07/01/13 19:50, Rick Fielden wrote:
> Being a raw 'newbie', how can I modify an existing shp file? I have a 50
> state county file and want to include only select states. Any assistance
> would be appreciated as none of my attempts have been successful.
> Hi Rick!
> More than one option (as always with computers)
> You said you have selected the states you want to include in the shape ..
> well:
> First of all to edit a shape file you have to switch it to edit mode ..
> probably you have already done that.
> Then you can select some polygons (they should now have small red dots at
> their nodes) - One way would be to select the polygons you don't want to
> have - and delete them ..
> Or (maybe without switching to editing mode - though not tested now) you
> have to select the states you want to have in the (new) shapefile (with
> CTRL pressed you can select more than one at a time) - right click on the
> layer and say "Save selection as" - You will than create a new shapefile
> including the selected polygons..
> Hope that helps you
> kind regards
> Werner
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20130107/197edba8/attachment.html>
