[Qgis-user] Newbie with request for advice
Eric Goddard
egoddard1010 at gmail.com
Thu Jan 10 20:16:26 PST 2013
Before you can compile the samples or compile GDAL with FGDB support you
have to link the FGDB library so the system can find it. Before running
make in the FileGDB_API/samples directory, create a text file in the
/etc/ld.so.conf.d/ to hold the path to wherever you FileGDB_API/lib folder
is located and run ldconfig to update it. On Ubuntu executing the following
lines in bash should fix it:
sudo sh -c "echo '/path/to/FileGDB_API/lib' >> /etc/ld.so.conf.d/fgdb.conf"
sudo ldconfig
after that, make should work.
Eric
On Fri, Jan 4, 2013 at 1:49 PM, Art <alf1361 at zoho.com> wrote:
> Yes! Any information on implementing this feature on Linux would be much
> appreciated.
> Art
> On 1/4/2013 8:08 AM, Johan Nilsson wrote:
> I'm also very interested in 'ESRI file geodatabase', not the 'Personal
> geodatabase', ( mdb or ms-access, or JET database) that ESRI not recommend
> to use...
> I tried to compile for month ago, but I think I stuck on the same place
> Art get stuck..
> /Cheers
> 2013/1/4 Randal Hale <rjhale at northrivergeographic.com>
>> Hi Art,
>> So I've got QGIS running on windows and linux. I haven't tried to compile
>> file geodatabase support into my linux install (that's on my list to do).
>> On my windows install I'm running OSGeo4Win - adding file based geodatabase
>> support was easy - I just added the "module" and had support (I'm currently
>> on my linux machine and not near my windows machine - or I would tell you
>> exactly what I added).
>> My windows machine is running Windows 7 64bit - my linux machine is
>> running xubuntu. I own a consulting business and have ArcGIS running on my
>> windows machine. There's not way I'm ever going to windows 8. So I'm
>> sticking with windows 7 for ESRI and migrating as much of my workflow over
>> to linux as I can...as I tell people - A clip is a clip and a buffer is a
>> buffer. So I'll do what I can on linux and when I have to go with ESRI I'll
>> jump over to windows.
>> Now that I read all of this - I should really try to compile file based
>> support on this laptop over the weekend.
>> Randy
>> Randal Hale, GISP
>> North River Geographic Systems, Inchttp://www.northrivergeographic.com 423.653.3611 rjhale at northrivergeographic.com
>> twitter:rjhale http://about.me/rjhale
>> On 01/01/2013 03:05 PM, Art wrote:
>> I have two options right now. I am a Linux lover, and I am investigating
>> compiling the Esri File Geodatabase API on Linux. However, the other option
>> is to handle it all through Windows, probably using OsGeo4Win. That means I
>> would probably have to make a switch to Windows. I do have a copy of ESRI's
>> ArcGIS that will work until August that was given to me for a GIS Course,
>> so I will have that option for some time but it will not be permanent. Does
>> anyone have a recommended course of action? I have attached the results
>> from my last compile attempt involving the File Geodatabase API. I have not
>> found a detailed set of compiling instructions to make and install it, and
>> am uncertain as to how I should proceed further.
>> Art
>> Qgis-user mailing listQgis-user at lists.osgeo.orghttp://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20130110/b189c96f/attachment.html>
