[Qgis-user] Newbie with request for advice
Art
alf1361 at zoho.com
Fri Jan 4 11:49:10 PST 2013
Yes! Any information on implementing this feature on Linux would be much
appreciated.
Art
On 1/4/2013 8:08 AM, Johan Nilsson wrote:
> I'm also very interested in 'ESRI file geodatabase', not the 'Personal
> geodatabase', ( mdb or ms-access, or JET database) that ESRI not
> recommend to use...
> I tried to compile for month ago, but I think I stuck on the same
> place Art get stuck..
> /Cheers
> 2013/1/4 Randal Hale <rjhale at northrivergeographic.com
> <mailto:rjhale at northrivergeographic.com>>
> Hi Art,
> So I've got QGIS running on windows and linux. I haven't tried to
> compile file geodatabase support into my linux install (that's on
> my list to do). On my windows install I'm running OSGeo4Win -
> adding file based geodatabase support was easy - I just added the
> "module" and had support (I'm currently on my linux machine and
> not near my windows machine - or I would tell you exactly what I
> added).
> My windows machine is running Windows 7 64bit - my linux machine
> is running xubuntu. I own a consulting business and have ArcGIS
> running on my windows machine. There's not way I'm ever going to
> windows 8. So I'm sticking with windows 7 for ESRI and migrating
> as much of my workflow over to linux as I can...as I tell people -
> A clip is a clip and a buffer is a buffer. So I'll do what I can
> on linux and when I have to go with ESRI I'll jump over to windows.
> Now that I read all of this - I should really try to compile file
> based support on this laptop over the weekend.
> Randy
> Randal Hale, GISP
> North River Geographic Systems, Inc
> http://www.northrivergeographic.com
> 423.653.3611 <tel:423.653.3611> rjhale at northrivergeographic.com <mailto:rjhale at northrivergeographic.com>
> twitter:rjhale
> http://about.me/rjhale
> On 01/01/2013 03:05 PM, Art wrote:
>> I have two options right now. I am a Linux lover, and I am
>> investigating compiling the Esri File Geodatabase API on Linux.
>> However, the other option is to handle it all through Windows,
>> probably using OsGeo4Win. That means I would probably have to
>> make a switch to Windows. I do have a copy of ESRI's ArcGIS that
>> will work until August that was given to me for a GIS Course, so
>> I will have that option for some time but it will not be
>> permanent. Does anyone have a recommended course of action? I
>> have attached the results from my last compile attempt involving
>> the File Geodatabase API. I have not found a detailed set of
>> compiling instructions to make and install it, and am uncertain
>> as to how I should proceed further.
>> Art
>> Qgis-user mailing list
>> Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20130104/f4228057/attachment.html>
