[Qgis-user] Newbie with request for advice
Johan Nilsson
joni8135 at gmail.com
Fri Jan 4 06:08:12 PST 2013
I'm also very interested in 'ESRI file geodatabase', not the 'Personal
geodatabase', ( mdb or ms-access, or JET database) that ESRI not recommend
to use...
I tried to compile for month ago, but I think I stuck on the same place Art
get stuck..
/Cheers
2013/1/4 Randal Hale <rjhale at northrivergeographic.com>
> Hi Art,
> So I've got QGIS running on windows and linux. I haven't tried to compile
> file geodatabase support into my linux install (that's on my list to do).
> On my windows install I'm running OSGeo4Win - adding file based geodatabase
> support was easy - I just added the "module" and had support (I'm currently
> on my linux machine and not near my windows machine - or I would tell you
> exactly what I added).
> My windows machine is running Windows 7 64bit - my linux machine is
> running xubuntu. I own a consulting business and have ArcGIS running on my
> windows machine. There's not way I'm ever going to windows 8. So I'm
> sticking with windows 7 for ESRI and migrating as much of my workflow over
> to linux as I can...as I tell people - A clip is a clip and a buffer is a
> buffer. So I'll do what I can on linux and when I have to go with ESRI I'll
> jump over to windows.
> Now that I read all of this - I should really try to compile file based
> support on this laptop over the weekend.
> Randy
> Randal Hale, GISP
> North River Geographic Systems, Inchttp://www.northrivergeographic.com 423.653.3611 rjhale at northrivergeographic.com
> twitter:rjhale http://about.me/rjhale
> On 01/01/2013 03:05 PM, Art wrote:
> I have two options right now. I am a Linux lover, and I am investigating
> compiling the Esri File Geodatabase API on Linux. However, the other option
> is to handle it all through Windows, probably using OsGeo4Win. That means I
> would probably have to make a switch to Windows. I do have a copy of ESRI's
> ArcGIS that will work until August that was given to me for a GIS Course,
> so I will have that option for some time but it will not be permanent. Does
> anyone have a recommended course of action? I have attached the results
> from my last compile attempt involving the File Geodatabase API. I have not
> found a detailed set of compiling instructions to make and install it, and
> am uncertain as to how I should proceed further.
> Art
> Qgis-user mailing listQgis-user at lists.osgeo.orghttp://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20130104/3e4b4de2/attachment.html>
