[Qgis-user] tutorial for qGIS API
Jonathan Moules jonathanmoules at warwickshire.gov.uk
Fri Jan 11 03:09:25 PST 2013
They do seem to be broken, but you can cheat.
If you use Google to search for the title (i.e: "Write a simple mapping
application using the new QGIS Canvas API <http://blog.qgis.org/?q=node/10>",
there's a "cached" link next to the result. This works for me and brings up
the desired page.
Cheers,
Jonathan
On 10 January 2013 14:09, MONOT Jean-Jacques <
jean-jacques.monot at thalesgroup.com> wrote:
> Hello,****
> I would like to write an app using the qGIS API.****
> The links to the tutorial are broken in the following page :****
> http://hub.qgis.org/wiki/quantum-gis/Developers_Corner****
> ===== broken links =================****
> Help on writing custom apps with QGIS API****
>    - Tutorial 1: Write a simple mapping application using the new QGIS
>    Canvas API <http://blog.qgis.org/?q=node/10>****
>    - Tutorial 2: Using MapTools with the QGIS Canvas API<http://blog.qgis.org/?q=node/14>
>    - Tutorial 3: Labelling map canvas features<http://blog.qgis.org/?q=node/23>
>    - Tutorial 4: Adding a raster to the map canvas<http://blog.qgis.org/?q=node/27>
>    - Tutorial 5: Creating temporary features on the map canvas<http://blog.qgis.org/?q=node/28>
>    - Tutorial 6: Working with vector feature attributes<http://blog.qgis.org/?q=node/32>
> Can someone help to get these tutorials ? or can provide me new ones ?****
> Best regards.****
> Mr Jean-Jacques MONOT ****
> ________________________
> Qgis-user mailing list
This transmission is intended for the named addressee(s) only and may contain sensitive or protectively marked material up to RESTRICTED and should be handled accordingly. Unless you are the named addressee (or authorised to receive it for the addressee) you may not copy or use it, or disclose it to anyone else. If you have received this transmission in error please notify the sender immediately. All email traffic sent to or from us,  including without limitation all GCSX traffic, may be subject to recording and/or monitoring in accordance with relevant legislation.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20130111/ae69b150/attachment.html>
