[Qgis-user] addons for GRASS through QGIS
Paolo Cavallini
cavallini at faunalia.it
Fri Jan 18 05:57:41 PST 2013
Il 18/01/2013 11:19, Illya Santos ha scritto:
> Is it possible to add GRASS addons from within QGIS via g.extension
> from the shell?
> I can run g.extension from the shell and list the addons including the
> one I want which is r.viewshed but I am unsure about how to configure
> the addon path or compile the addon maybe and put it in
> manually......or even if you can do this....
The GRASS shell inside QGIS is a proper shell, so if you can do it from
GRASS you should be able to do it from within QGIS.
Please try and report back.
Thanks.
Paolo Cavallini - Faunalia
www.faunalia.eu
Full contact details at www.faunalia.eu/pc
Nuovi corsi QGIS e PostGIS: http://www.faunalia.it/calendario
