[Qgis-user] Point2One plugin error
Goyo
goyodiaz at gmail.com
Fri Jan 18 08:39:54 PST 2013
The updated plugin can be downloaded from https://launchpad.net/points2one
I'll try to upload it to the QGIS plugin repo as soon as possible but
in the meantime you can install it manually:
1. Uninstall the plugin using the plugin manager
1. Download the zip file (points2one-0.2.9.zip) and unzip it
2. Copy the unzipped folder into ~/.qgis/python/plugins/
2013/1/18 Paulo van Breugel <p.vanbreugel at gmail.com>:
> Thanks, looking forward to the update
> On 01/18/2013 12:21 AM, Goyo wrote:
> Hi Paulo. This is triggered by the changes in the GQIS API. I'll
> update the plugin to work with the new API as soon as possible.
> Goyo
> 2013/1/15 Paulo van Breugel <p.vanbreugel at gmail.com>:
> Hi, when trying to use the Point2One plugin, I am getting the error shown
> below. This is on QGIS 1.9 (on Ubuntu 12.10). On QGIS 1.8 it works fine.
> Traceback (most recent call last):
> File "/home/paulo/.qgis//python/plugins/points2one/points2one_gui.py",
> line 119, in accept
> engine.run()
> File "/home/paulo/.qgis//python/plugins/points2one/p2o_engine.py", line
> 58, in run
> provider.fields(), self.wkb_type, self.layer.srs())
> AttributeError: 'QgsVectorLayer' object has no attribute 'srs'
> Python version:
> 2.7.3 (default, Sep 26 2012, 21:53:55)
> [GCC 4.7.2]
> Cheers
> Paulo
> Qgis-user mailing list
