[Qgis-user] Point2One plugin error
Nathan Woodrow
madmanwoo at gmail.com
Fri Jan 18 21:16:52 PST 2013
Goyo,
I approved you new plugin in the plugin repo. It should now show up in the
installer. Any future plugins that you post will also be auto approved.
Regards,
Nathan
On Sat, Jan 19, 2013 at 2:39 AM, Goyo <goyodiaz at gmail.com> wrote:
> The updated plugin can be downloaded from https://launchpad.net/points2one
> I'll try to upload it to the QGIS plugin repo as soon as possible but
> in the meantime you can install it manually:
> 1. Uninstall the plugin using the plugin manager
> 1. Download the zip file (points2one-0.2.9.zip) and unzip it
> 2. Copy the unzipped folder into ~/.qgis/python/plugins/
> 2013/1/18 Paulo van Breugel <p.vanbreugel at gmail.com>:
> > Thanks, looking forward to the update
> > On 01/18/2013 12:21 AM, Goyo wrote:
> > Hi Paulo. This is triggered by the changes in the GQIS API. I'll
> > update the plugin to work with the new API as soon as possible.
> > Goyo
> > 2013/1/15 Paulo van Breugel <p.vanbreugel at gmail.com>:
> > Hi, when trying to use the Point2One plugin, I am getting the error shown
> > below. This is on QGIS 1.9 (on Ubuntu 12.10). On QGIS 1.8 it works fine.
> > Traceback (most recent call last):
> > File "/home/paulo/.qgis//python/plugins/points2one/points2one_gui.py",
> > line 119, in accept
> > engine.run()
> > File "/home/paulo/.qgis//python/plugins/points2one/p2o_engine.py", line
> > 58, in run
> > provider.fields(), self.wkb_type, self.layer.srs())
> > AttributeError: 'QgsVectorLayer' object has no attribute 'srs'
> > Python version:
> > 2.7.3 (default, Sep 26 2012, 21:53:55)
> > [GCC 4.7.2]
> > Cheers
> > Paulo
> > Qgis-user mailing list
> > Qgis-user at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20130119/61e287be/attachment.html>
