[Qgis-user] Point2One plugin error
Paulo van Breugel
p.vanbreugel at gmail.com
Sat Jan 19 02:28:51 PST 2013
Great thanks Goyo
On Sat 19 Jan 2013 06:16:52 AM CET, Nathan Woodrow wrote:
> Goyo,
> I approved you new plugin in the plugin repo. It should now show up
> in the installer. Any future plugins that you post will also be auto
> approved.
> Regards,
> Nathan
> On Sat, Jan 19, 2013 at 2:39 AM, Goyo <goyodiaz at gmail.com
> <mailto:goyodiaz at gmail.com>> wrote:
> The updated plugin can be downloaded from
> https://launchpad.net/points2one
> I'll try to upload it to the QGIS plugin repo as soon as possible but
> in the meantime you can install it manually:
> 1. Uninstall the plugin using the plugin manager
> 1. Download the zip file (points2one-0.2.9.zip) and unzip it
> 2. Copy the unzipped folder into ~/.qgis/python/plugins/
> 2013/1/18 Paulo van Breugel <p.vanbreugel at gmail.com
> <mailto:p.vanbreugel at gmail.com>>:
> > Thanks, looking forward to the update
> > On 01/18/2013 12:21 AM, Goyo wrote:
> > Hi Paulo. This is triggered by the changes in the GQIS API. I'll
> > update the plugin to work with the new API as soon as possible.
> > Goyo
> > 2013/1/15 Paulo van Breugel <p.vanbreugel at gmail.com
> > Hi, when trying to use the Point2One plugin, I am getting the
> error shown
> > below. This is on QGIS 1.9 (on Ubuntu 12.10). On QGIS 1.8 it
> works fine.
> > Traceback (most recent call last):
> > File
> "/home/paulo/.qgis//python/plugins/points2one/points2one_gui.py",
> > line 119, in accept
> > engine.run()
> > File
> "/home/paulo/.qgis//python/plugins/points2one/p2o_engine.py", line
> > 58, in run
> > provider.fields(), self.wkb_type, self.layer.srs())
> > AttributeError: 'QgsVectorLayer' object has no attribute 'srs'
> > Python version:
> > 2.7.3 (default, Sep 26 2012, 21:53:55)
> > [GCC 4.7.2]
> > Cheers
> > Paulo
> > Qgis-user mailing list
> > Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
> > http://lists.osgeo.org/mailman/listinfo/qgis-user
