[Qgis-user] QGIS Master
Jonathan Moules
jonathanmoules at warwickshire.gov.uk
Wed Jan 23 04:55:12 PST 2013
Hi List,
I'm trying to get QGIS Master for Windows to test some of my bugs. I'm
sitting behind a corporate Proxy that requires a username/password.
The OSGeo4W Installer has a proxy option but can't handle our proxy it
seems so just stalls.
There is an option for installing from pre-downloaded files. Where can I
get those files from without using the OSGeo4W installer?
Cheers,
Jonathan
This transmission is intended for the named addressee(s) only and may contain sensitive or protectively marked material up to RESTRICTED and should be handled accordingly. Unless you are the named addressee (or authorised to receive it for the addressee) you may not copy or use it, or disclose it to anyone else. If you have received this transmission in error please notify the sender immediately. All email traffic sent to or from us, including without limitation all GCSX traffic, may be subject to recording and/or monitoring in accordance with relevant legislation.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20130123/0c0fc287/attachment.html>
