[Qgis-user] QGIS Master
Nathan Woodrow
madmanwoo at gmail.com
Wed Jan 23 05:14:21 PST 2013
Jonathan,
I have you tried the "Use IE Settings" option. I'm behind a firewall at
work and that seems to work for me.
- Nathan
On Wed, Jan 23, 2013 at 10:55 PM, Jonathan Moules <
jonathanmoules at warwickshire.gov.uk> wrote:
> Hi List,
> I'm trying to get QGIS Master for Windows to test some of my bugs. I'm
> sitting behind a corporate Proxy that requires a username/password.
> The OSGeo4W Installer has a proxy option but can't handle our proxy it
> seems so just stalls.
> There is an option for installing from pre-downloaded files. Where can I
> get those files from without using the OSGeo4W installer?
> Cheers,
> Jonathan
> This transmission is intended for the named addressee(s) only and may
> contain sensitive or protectively marked material up to RESTRICTED and
> should be handled accordingly. Unless you are the named addressee (or
> authorised to receive it for the addressee) you may not copy or use it, or
> disclose it to anyone else. If you have received this transmission in error
> please notify the sender immediately. All email traffic sent to or from us,
> including without limitation all GCSX traffic, may be subject to recording
> and/or monitoring in accordance with relevant legislation.
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20130123/e030e99f/attachment.html>
