[Qgis-user] QGIS Master
Andreas Neumann
a.neumann at carto.net
Wed Jan 23 05:29:08 PST 2013
Yes, the "Use IE settings" options works for me as well. Please try
that first before looking for alternatives.
Andreas
On Wed, 23 Jan 2013 23:14:21 +1000, Nathan Woodrow wrote:
> Jonathan,
> I have you tried the "Use IE Settings" option. I'm behind a firewall
> at work and that seems to work for me.
> - Nathan
> On Wed, Jan 23, 2013 at 10:55 PM, Jonathan Moules wrote:
>> Hi List,
>> I'm trying to get QGIS Master for Windows to test some of my bugs.
>> I'm sitting behind a corporate Proxy that requires a
>> username/password.
>> The OSGeo4W Installer has a proxy option but can't handle our proxy
>> it seems so just stalls.
>> There is an option for installing from pre-downloaded files. Where
>> can I get those files from without using the OSGeo4W installer?
>> Cheers,
>> Jonathan
>> This transmission is intended for the named addressee(s) only and
>> may contain sensitive or protectively marked material up to
>> RESTRICTED and should be handled accordingly. Unless you are the
>> named addressee (or authorised to receive it for the addressee) you
>> may not copy or use it, or disclose it to anyone else. If you have
>> received this transmission in error please notify the sender
>> immediately. All email traffic sent to or from us, including without
>> limitation all GCSX traffic, may be subject to recording and/or
>> monitoring in accordance with relevant legislation.
>> Qgis-user mailing list
>> Qgis-user at lists.osgeo.org [1]
>> http://lists.osgeo.org/mailman/listinfo/qgis-user [2]
> Links:
> [1] mailto:Qgis-user at lists.osgeo.org
> [2] http://lists.osgeo.org/mailman/listinfo/qgis-user
> [3] mailto:jonathanmoules at warwickshire.gov.uk
Andreas Neumann
Böschacherstrasse 10A
8624 Grüt (Gossau ZH)
Switzerland
