[Qgis-user] QGIS Master
Jonathan Moules
jonathanmoules at warwickshire.gov.uk
Wed Jan 23 06:37:32 PST 2013
Somehow I missed that option. Thanks both, that worked.
Jonathan
On 23 January 2013 13:29, Andreas Neumann <a.neumann at carto.net> wrote:
> Hi,
> Yes, the "Use IE settings" options works for me as well. Please try that
> first before looking for alternatives.
> Andreas
> On Wed, 23 Jan 2013 23:14:21 +1000, Nathan Woodrow wrote:
>> Jonathan,
>> I have you tried the "Use IE Settings" option. I'm behind a firewall
>> at work and that seems to work for me.
>> - Nathan
>> On Wed, Jan 23, 2013 at 10:55 PM, Jonathan Moules wrote:
>> Hi List,
>>> I'm trying to get QGIS Master for Windows to test some of my bugs.
>>> I'm sitting behind a corporate Proxy that requires a
>>> username/password.
>>> The OSGeo4W Installer has a proxy option but can't handle our proxy
>>> it seems so just stalls.
>>> There is an option for installing from pre-downloaded files. Where
>>> can I get those files from without using the OSGeo4W installer?
>>> Cheers,
>>> Jonathan
>>> This transmission is intended for the named addressee(s) only and
>>> may contain sensitive or protectively marked material up to
>>> RESTRICTED and should be handled accordingly. Unless you are the
>>> named addressee (or authorised to receive it for the addressee) you
>>> may not copy or use it, or disclose it to anyone else. If you have
>>> received this transmission in error please notify the sender
>>> immediately. All email traffic sent to or from us, including without
>>> limitation all GCSX traffic, may be subject to recording and/or
>>> monitoring in accordance with relevant legislation.
>>> ______________________________**_________________
>>> Qgis-user mailing list
>>> Qgis-user at lists.osgeo.org [1]
>>> http://lists.osgeo.org/**mailman/listinfo/qgis-user<http://lists.osgeo.org/mailman/listinfo/qgis-user>[2]
>> Links:
>> [1] mailto:Qgis-user at lists.osgeo.**org <Qgis-user at lists.osgeo.org>
>> [2] http://lists.osgeo.org/**mailman/listinfo/qgis-user<http://lists.osgeo.org/mailman/listinfo/qgis-user>
>> [3] mailto:jonathanmoules@**warwickshire.gov.uk<jonathanmoules at warwickshire.gov.uk>
> Andreas Neumann
> Böschacherstrasse 10A
> 8624 Grüt (Gossau ZH)
> Switzerland
This transmission is intended for the named addressee(s) only and may contain sensitive or protectively marked material up to RESTRICTED and should be handled accordingly. Unless you are the named addressee (or authorised to receive it for the addressee) you may not copy or use it, or disclose it to anyone else. If you have received this transmission in error please notify the sender immediately. All email traffic sent to or from us, including without limitation all GCSX traffic, may be subject to recording and/or monitoring in accordance with relevant legislation.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20130123/e8336614/attachment.html>
