[Qgis-user] Problem loading map using QGIS web client on Windows 7
Marco Hugentobler marco.hugentobler at sourcepole.ch
Wed Jan 23 23:41:36 PST 2013
>In Globaloptions.js, i have following variable:
>var serverAndCGI =
>"http://localhost/qgis-web-client-master/cgi-bin/qgis_mapserv.fcgi";
Shouldn't that point to the same server instance that works with the WMS
request?
http://localhost/qgis/qgis_mapserv.fcgi.exe
Regards,
Marco
On 23.01.2013 13:38, zbynek wrote:
> Hello,
> I am trying to run QGIS server with QGIS Web Client and have problem
> displaying map.
> I am using Windows 7.
> My DocumentRoot is "C:\OSGeo4W/Apache/htdocs"
> QGIS web client is in directory
> "c:\OSGeo4W\apache\htdocs\qgis-web-client-master\"
> QGIS server is running ok, following link shows map and map can be loaded to
> QGis desktop client as WMS
> http://localhost/qgis/qgis_mapserv.fcgi.exe?SERVICE=WMS&VERSION=1.3.0&SRS=EPSG:4326&REQUEST=GetMap&map=c:/OSGeo4W/apache/htdocs/qgis-web-client-master/projects/helloworld.qgs&BBOX=-50,10,0,90&WIDTH=1000&HEIGHT=1000&LAYERS=Country,Hello&FORMAT=image/png
> However, when i try to display the same qgis project using web client, it is
> stuck on "loading map" - side bars etc. are shown, map, however, is not.
> I followed this thread:
> http://osgeo-org.1560.n6.nabble.com/QGIS-WEB-Client-Qgis-Server-td4983593.html
> but without succes.
> My index.html includes this link to qgis web client:
> <li class="map-item"> HelloWorld - 4326
> <qgiswebclient.html?map=c:/OSGeo4W/apache/htdocs/qgis-web-client-master/projects/helloworld.qgs&format=image/png&visibleLayers=Hello,Country>
> </li>
> var serverAndCGI =
> and this file contains single line:
> c:/OSGeo4W/apps/qgis/bin/qgis_mapserv.fcgi.exe
> which points to the location of QGIS server
> I suppose, the problem must be in QGIS web client configuration, since
> webserver runs just fine, but i cannot find it.
> Any help would be much appreciated.
> Thanks,
> Zbynek
> View this message in context: http://osgeo-org.1560.n6.nabble.com/Problem-loading-map-using-QGIS-web-client-on-Windows-7-tp5029267.html
> Sent from the Quantum GIS - User mailing list archive at Nabble.com.
> Qgis-user mailing list
Dr. Marco Hugentobler
Sourcepole -  Linux & Open Source Solutions
Weberstrasse 5, CH-8004 Zürich, Switzerland
marco.hugentobler at sourcepole.ch http://www.sourcepole.ch
Technical Advisor QGIS Project Steering Committee
