[Qgis-user] QGIS and Python Errors
Stephane Goldstein s.n.g at gmx.com
Thu Jan 31 08:46:59 PST 2013
Thanks, it worked just like you said!
 But adding back the variables I had in PYTHONPATH
 C:\Python27\Lib
 C:\Python27\DLLs
 C:\Python27\Lib\lib-tk
 C:\mapnik-2.0.1rc0\python\2.7\site-packages
 Made Sextante stop working on QGIS 1.9.
 Then I removed the first 3 ones and left only the last.
 Now Mapnik and Sextante both work.
 Don't know why I added these first three variables, I read somewhere that they are needed, but it doesn't seem so.
 Thanks a lot!
----- Original Message -----
Sent: 01/31/13 02:32 PM
To: Stephane Goldstein
Subject: Re: [Qgis-user] QGIS and Python Errors
The error you are getting there is to do with the API change in 1.9 (the dev version). If you change
QgsMapLayerRegistry.instance().addMapLayer(layer)
to
QgsMapLayerRegistry.instance().addMapLayers([layer])
it will work again.
QGIS will use the Python installed with OSGeo4W, I don't think also having standalone copy of Python installed will cause any issues.
- Nathan
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20130131/4bf51c46/attachment.html>
