[Qgis-user] QGIS and Python Errors
Andre Joost
andre+joost at nurfuerspam.de
Thu Jan 31 08:42:38 PST 2013
Hello,
I have installed Python 27 and Mapnik completely separate from the
OSGeo4w path, to avoid any interference. PATH and PYTHONPATH both point
to the standalone versions, while Qgis and Osgeo4w set their own path
with qgis.bat and osgeo4w.bat until the end of the session.
Greetings,
André Joost
Am 31.01.2013 15:26, schrieb Stephane Goldstein:
> Hello.
> I'm running QGIS 1.8 and 1.9 on Windows 7 x64. I installed them using the OSGeo4W installer.
> Everything was going fine untill I installed Python 2.7 to start learning Mapnik.
> I instaled Python x64, then realised it has to be x86 to run with Mapnik.
> I uninstaled the Python x64 and installed x86, and start going with Mapnik.
> Since then my QGIS started giving me a lot of errors. Sextante wouldn´t load, giving error message on start-up.
> I was able to fix this by removing the paths to Python and Mapnik I have added on the System Variables.
> But now I'm still having other problems, the main one for me right now beeing QSpatialite.
> I can run queries, but if I ask the output to be displayed in a QGIS layer I got the error pasted below.
> Is there something I can do to make things run smoothly again ? I already reinstalled all OSGeo4W packages, but no sucess.
> I see that OSGEO has it's own python, is this creating some kind of conflict ?
> Thank you
> An error has occured while executing Python code:
> Traceback (most recent call last):
> File "C:/Users/winste/.qgis//python/plugins\QspatiaLite\QspatiaLiteApp.py", line 195, in runQuery
> loadInQGIS_spatial(self,self.db,query,geomfield,tablename)
> File "C:/Users/winste/.qgis//python/plugins\QspatiaLite\Utility_functions.py", line 173, in loadInQGIS_spatial
> QgsMapLayerRegistry.instance().addMapLayer(layer)
> AttributeError: 'QgsMapLayerRegistry' object has no attribute 'addMapLayer'
> Python version:
> 2.7.2 (default, Jun 12 2011, 15:08:59) [MSC v.1500 32 bit (Intel)]
> QGIS version:
> 1.9.0-Master Master, 2a4d79d
> Python path: ['C:/Users/winste/.qgis//python/plugins\\sextante', 'C:/OSGeo4W/apps/qgis-dev/./python', 'C:/Users/winste/.qgis//python', 'C:/Users/winste/.qgis//python/plugins', 'C:/OSGeo4W/apps/qgis-dev/./python/plugins', 'C:\\OSGeo4W\\bin\\python27.zip', 'C:\\OSGeo4W\\apps\\Python27\\DLLs', 'C:\\OSGeo4W\\apps\\Python27\\lib', 'C:\\OSGeo4W\\apps\\Python27\\lib\\plat-win', 'C:\\OSGeo4W\\apps\\Python27\\lib\\lib-tk', 'C:\\OSGeo4W\\bin', 'C:\\OSGeo4W\\apps\\Python27', 'C:\\OSGeo4W\\apps\\Python27\\lib\\site-packages', 'C:\\OSGeo4W\\apps\\Python27\\lib\\site-packages\\PIL', 'C:\\OSGeo4W\\apps\\Python27\\lib\\site-packages\\win32', 'C:\\OSGeo4W\\apps\\Python27\\lib\\site-packages\\win32\\lib', 'C:\\OSGeo4W\\apps\\Python27\\lib\\site-packages\\Pythonwin', 'C:\\OSGeo4W\\apps\\Python27\\lib\\site-packages\\wx-2.8-msw-unicode', 'C:\\OSGeo4W\\apps\\qgis-dev\\python\\plugins\\fTools\\tools']
> Qgis-user mailing list
