[Qgis-user] lost 'fetch python plugins' and vector menu
    Robert Nuske
    rnuske at gwdg.de
    Thu Jul  4 08:33:01 PDT 2013
Hi Etienne,
yes you are right, I obviously looked not carefully enough...
Anyhow, the given solution is not working for me.
python-pyspatialite is not installed, at least not after purging
all qgis packages.
I now also removed libspatialite5 and libspatialite3, which tore down the
entire grass and gdal
Then started again with installing qgis (ends up pulling again libspatialite3
and libspatialite5 ), but nothing changed.  Still no  'fetch python plugins'
and no vector menu
Is there another repository I should use besides or instead
ubuntugis-unstable?
cheers,
  robert
Am Donnerstag, 4. Juli 2013, 12:07:02 schrieb Etienne Tourigny:
> another user reported in a separate thread of this same list a few days ago
> (subject is "Fetch plugins missing")
> "I had to remove python-pyspatialite to get a correct installation of
> python-qgis and get the python plugins working"
> It's always a good idea to look for existing solutions in the mailing list
> before posting...
> cheers
> Etienne
> On Thu, Jul 4, 2013 at 12:02 PM, Robert Nuske <rnuske at gwdg.de> wrote:
> > Dear partners in misery and merciful helpers,
> > I've got the feeling the 1.8.0-2~raring1 QGIS package from
> > ubuntugis-unstable for 13.04 64bit is broken.
> > Yes, I did
> > - purge every qgis package separately
> > - delete all the .qgis folders
> > - now also reboot and aptitude update & aptitude dist-upgrade
> > (no idea what for)
> > - a fresh install of the qgis package
> > The old 1.8.0-1~quantal3 32bit QGIS package on another computer works
> > like a charm. I hope I do not have to build from source to get a working
> > QGIS 1.8 on a recent Ubuntu.
> > Is the package really broken or did I do something utterly wrong?
> > cheers,
> > robert
> > Am Donnerstag, 4. Juli 2013, 14:53:44 schrieb Saber Razmjooei:
> > > If you run qgis from terminal, what error message(s) do you get?
> > > From: Joshua Hattingh [mailto:josh at rockstock.co.za]
> > > Sent: 04 July 2013 14:52
> > > To: Saber Razmjooei
> > > Cc: Nathan Woodrow; qgis-user at lists.osgeo.org; Robert Nuske
> > > Subject: Re: [Qgis-user] lost 'fetch python plugins' and vector menu
> > > Tried that, still no luck - no fetch python plugins and no openlayers
> > > plugin.
> > > J
> > > On 4 July 2013 15:42, Saber Razmjooei
> > > <saber.razmjooei at lutraconsulting.co.uk> wrote:
> > > If you are using 1.8, I guess there is no API change for it, so the
> > > following should do:
> > > sudo apt-get purge python-qgis
> > > sudo apt-get update
> > > sudo apt-get dist-upgrade
> > > sudo apt-get install python-qgis
> > > Just to be 100% sure!
> > > Cheers
> > > Saber
> > > www.lutraconsulting.co.uk <http://www.lutraconsulting.co.uk/>
> > > From: qgis-user-bounces at lists.osgeo.org
> > > [mailto:qgis-user-bounces at lists.osgeo.org] On Behalf Of Joshua Hattingh
> > > Sent: 04 July 2013 14:38
> > > To: Nathan Woodrow
> > > Cc: qgis-user at lists.osgeo.org; Robert Nuske
> > > Can we fix our installations? If so, how? In point form. Do A then B
> > then C
> > > etc.
> > > Thanks,
> > > J
> > > On 4 July 2013 15:34, Nathan Woodrow <madmanwoo at gmail.com> wrote:
> > > The plugin install has been merged into the plugin manager.
> > > The API has also chmaged so all plugins need to be updated. This is why
> > you
> > > are missing some of the plugins you used to have.
> > > Sent from some fancy phone looking thingo
> > > _____
> > > Sent: 4/07/2013 11:29 PM
> > > To: Robert Nuske
> > > Hi Robert
> > > I have the same problem (I'm trying to get Openlayers plugin but also
> > don't
> > > have the "Fetch Python Plugins" menu option, and can't get help
> > > anywhere,
> > > been through the same methods as you. I'm on Raring and 1.8 or 1.9 and
> > same
> > > problem on both. I've tried for 2 weeks to fix but cannot. Let me know
> > > if
> > > you find the secret. There's a fix but it doesn't work for me.
> > > Regards,
> > > Josh
> > > On 4 July 2013 14:38, Robert Nuske <rnuske at gwdg.de> wrote:
> > > Dear QGISers,
> > > somehow I have no vector menu and can not find the menu entry
> > > 'fetch python plugins'.
> > > Being on Kubuntu 13.04 64bit I have my QGIS (1.8.0-2~raring1) from
> > > ubuntugis-unstable.
> > > I deleted any .qgis folders, purged any qgis package and did a fresh
> > install
> > > of qgis (aptitude install qgis). I have no clue what else I could/should
> > > try.
> > > Any help is more than appreciated
> > > cheers,
> > > robert
> > > Additional Information:
> > > $ sudo apt-cache policy qgis
> > > qgis:
> > > Installiert: 1.8.0-2~raring1
> > > Installationskandidat: 1.8.0-2~raring1
> > > Versionstabelle:
> > > *** 1.8.0-2~raring1 0
> > > 500 http://ppa.launchpad.net/ubuntugis/ubuntugis-unstable/ubuntu/
> > > raring/main amd64 Packages
> > > 100 /var/lib/dpkg/status
> > > 1.7.4+1.7.5~20120320-1.1 0
> > > 500 http://de.archive.ubuntu.com/ubuntu/ raring/universe amd64 Packages
> > > $ sudo aptitude search qgis
> > > p libqgis-dev - Quantum GIS - development files
> > > p libqgis-dev:i386 - Quantum GIS - development files
> > > p libqgis1.7.5 - Quantum GIS - shared libraries
> > > p libqgis1.7.5:i386 - Quantum GIS - shared libraries
> > > i A libqgis1.8.0 - Quantum GIS - shared libraries
> > > p libqgis1.8.0:i386 - Quantum GIS - shared libraries
> > > i A python-qgis - Python bindings to Quantum GIS
> > > p python-qgis:i386 - Python bindings to Quantum GIS
> > > i A python-qgis-common - Python bindings to Quantum GIS - ar
> > > v python2.7-qgis -
> > > v python2.7-qgis:i386 -
> > > i qgis - Geografisches Informationssystem (G
> > > p qgis:i386 - Geografisches Informationssystem (G
> > > p qgis-api-doc - Quantum GIS API documentation
> > > i A qgis-common - Quantum GIS - architecture-independ
> > > v qgis-dev -
> > > v qgis-dev:i386 -
> > > p qgis-mapserver - Quantum GIS mapserver
> > > p qgis-mapserver:i386 - Quantum GIS mapserver
> > > i A qgis-plugin-globe - OSG globe plugin for Quantum GIS
> > > p qgis-plugin-globe:i386 - OSG globe plugin for Quantum GIS
> > > i A qgis-plugin-globe-common - OSG GLOBE plugin for Quantum GIS -
> > > i A qgis-plugin-grass - GRASS plugin for Quantum GIS
> > > p qgis-plugin-grass:i386 - GRASS plugin for Quantum GIS
> > > i A qgis-plugin-grass-common - GRASS plugin for Quantum GIS - arch
> > > i A qgis-providers - collection of data providers to Qua
> > > p qgis-providers:i386 - collection of data providers to Qua
> > > i A qgis-providers-common - collection of data providers to Qua
> > > p qgis-sqlanywhere - Quantum GIS sql anywhere plugin and
> > > p qgis-sqlanywhere:i386 - Quantum GIS sql anywhere plugin and
> > > p qgis-sqlanywhere1.7.5 - Quantum GIS sql anywhere plugin and
> > > p qgis-sqlanywhere1.7.5:i386 - Quantum GIS sql anywhere plugin and
> > > _______________________________________________
> > > Qgis-user mailing list
> > > Qgis-user at lists.osgeo.org
> > > http://lists.osgeo.org/mailman/listinfo/qgis-user
> > > _____
> > > This email and any files transmitted with it are confidential and
> > intended
> > > solely for the use of the individual or entity to whom they are
> > addressed.
> > > If you have received this email in error please notify the system
> > manager.
> > > This message contains confidential information and is intended only for
> > the
> > > individual named. If you are not the named addressee you should not
> > > disseminate, distribute or copy this e-mail. Please notify the sender
> > > immediately by e-mail if you have received this e-mail by mistake and
> > delete
> > > this e-mail from your system. If you are not the intended recipient you
> > are
> > > notified that disclosing, copying, distributing or taking any action in
> > > reliance on the contents of this information is strictly prohibited.
> > > Whilst reasonable care has been taken to avoid virus transmission, no
> > > responsibility for viruses is taken and it is your responsibility to
> > carry
> > > out such checks as you feel appropriate.
> > > Saber Razmjooei and Peter Wells trading as Lutra Consulting.
