[Qgis-user] QGIS installation problem with Mac OSX 10.8.4 and some Qt4 Modules
Marcel Stadelmann marcel.stadelmann at gmx.net
Fri Jul 5 03:18:00 PDT 2013
Hi all,
Cmake the Master QGIS branch gives me the following error messages. It seems to be a problem with Qt4. I already reinstalled it, but it doesn't help. And there are no hints in the google net, so I'm lost. Can anybody help? Thank you.
Marcels-iMac:build Marcello$   cmake -D CMAKE_INSTALL_PREFIX=~/Applications \
>   -D CMAKE_BUILD_TYPE=MINSIZEREL -D ENABLE_TESTS=FALSE \
>   -D WITH_INTERNAL_SPATIALITE=FALSE -D WITH_PYSPATIALITE=FALSE \
>   -D SPATIALINDEX_LIBRARY=/usr/local/lib/libspatialindex.dylib \
>   -D SPATIALINDEX_INCLUDE_DIR=/usr/local/include/spatialindex \
>   -D QWT_LIBRARY=/usr/local/qwt-6.0.2/lib/libqwt.dylib \
>   -D QWT_INCLUDE_DIR=/usr/local/qwt-6.0.2/include \
>   -D BISON_EXECUTABLE=/usr/local/bin/bison \
-- QGIS version: 1.9.0 Master (10900)
-- Found GRASS: /Applications/GRASS-6.4.app/Contents/MacOS (6.4.2)
-- Found Proj: /Library/Frameworks/PROJ.framework
-- Found GEOS: /Library/Frameworks/GEOS.framework
-- Found GDAL: /usr/local/Cellar/gdal/1.9.2/lib/libgdal.dylib (1.9.2)
-- Found Expat: /usr/local/lib/libexpat.dylib
-- Found Spatialindex: /usr/local/lib/libspatialindex.dylib
-- Found Qwt: /usr/local/qwt-6.0.2/lib/libqwt.dylib (6.0.2)
-- Found Sqlite3: /Library/Frameworks/sqlite3.framework
-- Found PostgreSQL: /usr/local/pgsql-9.1/lib/libpq.dylib
-- Found SpatiaLite: /usr/local/lib/libspatialite.dylib
CMake Error at CMakeLists.txt:233 (MESSAGE):
  Some Qt4 modules haven't been found!
-- Touch support disabled
-- Found QScintilla2: /usr/local/lib/libqscintilla2.dylib (2.7.2)
Qt QTSVG library not found.
Qt QTWEBKIT library not found.
Qt QTGUI library not found.
Qt QTXML library not found.
Qt QTSQL library not found.
Qt QTNETWORK library not found.
-- Pedantic compiler settings enabled
-- Found Python executable: /System/Library/Frameworks/Python.framework/Versions/2.7/bin/python2.7
-- Found Python version: 2.7.2
-- Found Python library: -framework Python
-- Found SIP version: 4.14.4
-- Found PyQt4 version: 4.9.4
-- Found QScintilla2 PyQt4 module: 2.7
-- Found GSL: -L/usr/local/Cellar/gsl/1.15/lib -lgsl -lgslcblas
-- Found FCGI: /usr/local/lib/libfcgi.dylib
-- txt2tags not found - disabled
-- Configuring incomplete, errors occurred!
Here is the result of qmake -query:
Marcels-iMac:build Marcello$ qmake -query
QT_INSTALL_PREFIX:/
QT_INSTALL_DATA:/usr/local/Qt4.8
QT_INSTALL_DOCS:/Developer/Documentation/Qt
QT_INSTALL_HEADERS:/usr/include
QT_INSTALL_LIBS:/Library/Frameworks
QT_INSTALL_BINS:/Developer/Tools/Qt
QT_INSTALL_PLUGINS:/Developer/Applications/Qt/plugins
QT_INSTALL_IMPORTS:/Developer/Applications/Qt/imports
QT_INSTALL_TRANSLATIONS:/Developer/Applications/Qt/translations
QT_INSTALL_CONFIGURATION:/Library/Preferences/Qt
QT_INSTALL_EXAMPLES:/Developer/Examples/Qt/
QT_INSTALL_DEMOS:/Developer/Examples/Qt/Demos
QMAKE_MKSPECS:/usr/local/Qt4.8/mkspecs
QMAKE_VERSION:2.01a
QT_VERSION:4.8.5
