[Qgis-user] QGIS installation problem with Mac OSX 10.8.4 and some Qt4 Modules
William Kyngesburye
woklist at kyngchaos.com
Fri Jul 5 09:16:39 PDT 2013
Have you successfully comiled QGIS in the past?
Did you have any problems compiling SIP/PyQt after installing Qt 4.8.5? If updating to a newer Qt, did you recompile SIP/PyQt?
Are you following the compiling instructions in the INSTALL doc?
P.S. note about spatialite on OS X - if you use my SQLite framework, it includes spatialite, so there is no need to install your own. QGIS might get confused and crash if it finds another spatialite (ie in SQLite framework) than it was compiled with (ie /usr/local)
On Jul 5, 2013, at 5:18 AM, Marcel Stadelmann wrote:
> Hi all,
> Cmake the Master QGIS branch gives me the following error messages. It seems to be a problem with Qt4. I already reinstalled it, but it doesn't help. And there are no hints in the google net, so I'm lost. Can anybody help? Thank you.
> Marcels-iMac:build Marcello$ cmake -D CMAKE_INSTALL_PREFIX=~/Applications \
>> -D CMAKE_BUILD_TYPE=MINSIZEREL -D ENABLE_TESTS=FALSE \
>> -D WITH_INTERNAL_SPATIALITE=FALSE -D WITH_PYSPATIALITE=FALSE \
>> -D SPATIALINDEX_LIBRARY=/usr/local/lib/libspatialindex.dylib \
>> -D SPATIALINDEX_INCLUDE_DIR=/usr/local/include/spatialindex \
>> -D QWT_LIBRARY=/usr/local/qwt-6.0.2/lib/libqwt.dylib \
>> -D QWT_INCLUDE_DIR=/usr/local/qwt-6.0.2/include \
>> -D BISON_EXECUTABLE=/usr/local/bin/bison \
> -- QGIS version: 1.9.0 Master (10900)
> -- Found GRASS: /Applications/GRASS-6.4.app/Contents/MacOS (6.4.2)
> -- Found Proj: /Library/Frameworks/PROJ.framework
> -- Found GEOS: /Library/Frameworks/GEOS.framework
> -- Found GDAL: /usr/local/Cellar/gdal/1.9.2/lib/libgdal.dylib (1.9.2)
> -- Found Expat: /usr/local/lib/libexpat.dylib
> -- Found Spatialindex: /usr/local/lib/libspatialindex.dylib
> -- Found Qwt: /usr/local/qwt-6.0.2/lib/libqwt.dylib (6.0.2)
> -- Found Sqlite3: /Library/Frameworks/sqlite3.framework
> -- Found PostgreSQL: /usr/local/pgsql-9.1/lib/libpq.dylib
> -- Found SpatiaLite: /usr/local/lib/libspatialite.dylib
> CMake Error at CMakeLists.txt:233 (MESSAGE):
> Some Qt4 modules haven't been found!
> -- Touch support disabled
> -- Found QScintilla2: /usr/local/lib/libqscintilla2.dylib (2.7.2)
> Qt QTSVG library not found.
> Qt QTWEBKIT library not found.
> Qt QTGUI library not found.
> Qt QTXML library not found.
> Qt QTSQL library not found.
> Qt QTNETWORK library not found.
> -- Pedantic compiler settings enabled
> -- Found Python executable: /System/Library/Frameworks/Python.framework/Versions/2.7/bin/python2.7
> -- Found Python version: 2.7.2
> -- Found Python library: -framework Python
> -- Found SIP version: 4.14.4
> -- Found PyQt4 version: 4.9.4
> -- Found QScintilla2 PyQt4 module: 2.7
> -- Found GSL: -L/usr/local/Cellar/gsl/1.15/lib -lgsl -lgslcblas
> -- Found FCGI: /usr/local/lib/libfcgi.dylib
> -- txt2tags not found - disabled
> -- Configuring incomplete, errors occurred!
> Here is the result of qmake -query:
> Marcels-iMac:build Marcello$ qmake -query
> QT_INSTALL_PREFIX:/
> QT_INSTALL_DATA:/usr/local/Qt4.8
> QT_INSTALL_DOCS:/Developer/Documentation/Qt
> QT_INSTALL_HEADERS:/usr/include
> QT_INSTALL_LIBS:/Library/Frameworks
> QT_INSTALL_BINS:/Developer/Tools/Qt
> QT_INSTALL_PLUGINS:/Developer/Applications/Qt/plugins
> QT_INSTALL_IMPORTS:/Developer/Applications/Qt/imports
> QT_INSTALL_TRANSLATIONS:/Developer/Applications/Qt/translations
> QT_INSTALL_CONFIGURATION:/Library/Preferences/Qt
> QT_INSTALL_EXAMPLES:/Developer/Examples/Qt/
> QT_INSTALL_DEMOS:/Developer/Examples/Qt/Demos
> QMAKE_MKSPECS:/usr/local/Qt4.8/mkspecs
> QMAKE_VERSION:2.01a
> QT_VERSION:4.8.5
> Qgis-user mailing list
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
"We are at war with them. Neither in hatred nor revenge and with no particular pleasure I shall kill every ___ I can until the war is over. That is my duty."
"Don't you even hate 'em?"
"What good would it do if I did? If all the many millions of people of the allied nations devoted an entire year exclusively to hating the ____ it wouldn't kill one ___ nor shorten the war one day."
<Ha, ha> "And it might give 'em all stomach ulcers."
- Tarzan, on war
