[Qgis-user] QGIS installation problem with Mac OSX 10.8.4 and	some Qt4 Modules
    William Kyngesburye
    woklist at kyngchaos.com
    Sat Jul  6 16:33:06 PDT 2013
Current stable was 2.8.11 (what I have) until a few days ago.  2.8.11.2 was released Jul 3.  I don't see any changes in the latest release or in master that might cause this behavior.  2.8.11.2 still works for me, but I don't have anything in /usr/local that would confuse it.
On Jul 6, 2013, at 6:00 PM, Marcel Stadelmann wrote:
> Am 07.07.2013 um 00:53 schrieb William Kyngesburye <woklist at kyngchaos.com>:
>> This is very strange, cmake should be finding all the frameworks (GEOS, PROJ, SQLite/Spatialite) and not other libraries.  You have to explicitly set a cmake variable so it doesn't prefer frameworks over libraries.
>> Maybe cmake is misbehaving - what is your cmake version?
> where can I check the cmake version? I downloaded the master branch just a few hours ago.
>> On Jul 6, 2013, at 5:33 PM, Marcel Stadelmann wrote:
>>> I use Xcode 4.6.3
>>> Cmake QGIS didn't work. First GDAL was not found. After including -D GDAL_CONFIG=/Library/Frameworks/GDAL.framework/Versions/1.10/unix/bin/gdal-config it was found, but other errors occurred (see below). What could it be?
>>> Marcels-iMac:build Marcello$ cmake -D CMAKE_INSTALL_PREFIX=~/Applications \
>>>> -D CMAKE_BUILD_TYPE=MINSIZEREL -D ENABLE_TESTS=FALSE \
>>>> -D WITH_INTERNAL_SPATIALITE=FALSE -D WITH_PYSPATIALITE=FALSE \
>>>> -D SPATIALINDEX_LIBRARY=/usr/local/lib/libspatialindex.dylib \
>>>> -D SPATIALINDEX_INCLUDE_DIR=/usr/local/include/spatialindex \
>>>> -D QWT_LIBRARY=/usr/local/qwt-6.0.2/lib/libqwt.dylib \
>>>> -D QWT_INCLUDE_DIR=/usr/local/qwt-6.0.2/include \
>>>> -D BISON_EXECUTABLE=/usr/local/bin/bison \
>>>> -D GDAL_CONFIG=/Library/Frameworks/GDAL.framework/Versions/1.10/unix/bin/gdal-config \
>>> -- QGIS version: 1.9.0 Master (10900)
>>> -- Found GRASS: /Applications/GRASS-6.4.app/Contents/MacOS (6.4.2)
>>> -- Found Proj: /usr/local/lib/libproj.dylib
>>> -- Found GEOS: /usr/local/Cellar/geos/3.3.8/lib/libgeos_c.dylib
>>> -- Found GDAL: /Library/Frameworks/GDAL.framework/Versions/1.10/unix/lib/libgdal.dylib (1.10.0)
>>> -- Found Expat: /usr/local/lib/libexpat.dylib
>>> -- Found Spatialindex: /usr/local/lib/libspatialindex.dylib
>>> -- Found Qwt: /usr/local/qwt-6.0.2/lib/libqwt.dylib (6.0.2)
>>> -- Found Sqlite3: /usr/lib/libsqlite3.dylib
>>> -- Found PostgreSQL: /usr/local/pgsql-9.2/lib/libpq.dylib
>>> -- Touch support disabled
>>> -- Found QScintilla2: /usr/local/lib/libqscintilla2.dylib (2.7.2)
>>> -- Pedantic compiler settings enabled
>>> -- Found Python executable: /usr/bin/python
>>> -- Found Python version: 2.7.2
>>> -- Found Python library: -framework Python
>>> -- Found SIP version: 4.14.6
>>> -- Found PyQt4 version: 4.10.2
>>> -- Found QScintilla2 PyQt4 module: 2.7.2
>>> fatal: Not a git repository (or any of the parent directories): .git
>>> -- Found GSL: -L/usr/local/Cellar/gsl/1.15/lib -lgsl -lgslcblas
>>> -- txt2tags not found - disabled
>>> CMake Error: The following variables are used in this project, but they are set to NOTFOUND.
>>> Please set them or make sure they are set and tested correctly in the CMake files:
>>> SPATIALITE_LIBRARY
>>>  linked by target "qgis_core" in directory /Users/Marcello/Downloads/Quantum-GIS-master/src/core
>>>  linked by target "offlineeditingplugin" in directory /Users/Marcello/Downloads/Quantum-GIS-master/src/plugins/offline_editing
>>> -- Configuring incomplete, errors occurred!
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
Earth: "Mostly harmless"
- revised entry in the HitchHiker's Guide to the Galaxy
