[Qgis-user] QGIS installation problem with Mac OSX 10.8.4 and some Qt4 Modules
Marcel Stadelmann
marcel.stadelmann at gmx.net
Sun Jul 7 08:48:46 PDT 2013
I used cmake version 2.8.11.1 until yesterday, now i installed the version 2.8.11.2 but still the same error for SPATIALITE_LIBRARY appear. GDAL frameworks are now found without explicitly set a cmake variable.
Am 07.07.2013 um 01:33 schrieb William Kyngesburye <woklist at kyngchaos.com>:
> Current stable was 2.8.11 (what I have) until a few days ago. 2.8.11.2 was released Jul 3. I don't see any changes in the latest release or in master that might cause this behavior. 2.8.11.2 still works for me, but I don't have anything in /usr/local that would confuse it.
> On Jul 6, 2013, at 6:00 PM, Marcel Stadelmann wrote:
>> Am 07.07.2013 um 00:53 schrieb William Kyngesburye <woklist at kyngchaos.com>:
>>> This is very strange, cmake should be finding all the frameworks (GEOS, PROJ, SQLite/Spatialite) and not other libraries. You have to explicitly set a cmake variable so it doesn't prefer frameworks over libraries.
>>> Maybe cmake is misbehaving - what is your cmake version?
>> where can I check the cmake version? I downloaded the master branch just a few hours ago.
>>> On Jul 6, 2013, at 5:33 PM, Marcel Stadelmann wrote:
>>>> I use Xcode 4.6.3
>>>> Cmake QGIS didn't work. First GDAL was not found. After including -D GDAL_CONFIG=/Library/Frameworks/GDAL.framework/Versions/1.10/unix/bin/gdal-config it was found, but other errors occurred (see below). What could it be?
>>>> Marcels-iMac:build Marcello$ cmake -D CMAKE_INSTALL_PREFIX=~/Applications \
>>>>> -D CMAKE_BUILD_TYPE=MINSIZEREL -D ENABLE_TESTS=FALSE \
>>>>> -D WITH_INTERNAL_SPATIALITE=FALSE -D WITH_PYSPATIALITE=FALSE \
>>>>> -D SPATIALINDEX_LIBRARY=/usr/local/lib/libspatialindex.dylib \
>>>>> -D SPATIALINDEX_INCLUDE_DIR=/usr/local/include/spatialindex \
>>>>> -D QWT_LIBRARY=/usr/local/qwt-6.0.2/lib/libqwt.dylib \
>>>>> -D QWT_INCLUDE_DIR=/usr/local/qwt-6.0.2/include \
>>>>> -D BISON_EXECUTABLE=/usr/local/bin/bison \
>>>>> -D GDAL_CONFIG=/Library/Frameworks/GDAL.framework/Versions/1.10/unix/bin/gdal-config \
>>>> -- QGIS version: 1.9.0 Master (10900)
>>>> -- Found GRASS: /Applications/GRASS-6.4.app/Contents/MacOS (6.4.2)
>>>> -- Found Proj: /usr/local/lib/libproj.dylib
>>>> -- Found GEOS: /usr/local/Cellar/geos/3.3.8/lib/libgeos_c.dylib
>>>> -- Found GDAL: /Library/Frameworks/GDAL.framework/Versions/1.10/unix/lib/libgdal.dylib (1.10.0)
>>>> -- Found Expat: /usr/local/lib/libexpat.dylib
>>>> -- Found Spatialindex: /usr/local/lib/libspatialindex.dylib
>>>> -- Found Qwt: /usr/local/qwt-6.0.2/lib/libqwt.dylib (6.0.2)
>>>> -- Found Sqlite3: /usr/lib/libsqlite3.dylib
>>>> -- Found PostgreSQL: /usr/local/pgsql-9.2/lib/libpq.dylib
>>>> -- Touch support disabled
>>>> -- Found QScintilla2: /usr/local/lib/libqscintilla2.dylib (2.7.2)
>>>> -- Pedantic compiler settings enabled
>>>> -- Found Python executable: /usr/bin/python
>>>> -- Found Python version: 2.7.2
>>>> -- Found Python library: -framework Python
>>>> -- Found SIP version: 4.14.6
>>>> -- Found PyQt4 version: 4.10.2
>>>> -- Found QScintilla2 PyQt4 module: 2.7.2
>>>> fatal: Not a git repository (or any of the parent directories): .git
>>>> -- Found GSL: -L/usr/local/Cellar/gsl/1.15/lib -lgsl -lgslcblas
>>>> -- txt2tags not found - disabled
>>>> CMake Error: The following variables are used in this project, but they are set to NOTFOUND.
>>>> Please set them or make sure they are set and tested correctly in the CMake files:
>>>> SPATIALITE_LIBRARY
>>>> linked by target "qgis_core" in directory /Users/Marcello/Downloads/Quantum-GIS-master/src/core
>>>> linked by target "offlineeditingplugin" in directory /Users/Marcello/Downloads/Quantum-GIS-master/src/plugins/offline_editing
>>>> -- Configuring incomplete, errors occurred!
> William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
> http://www.kyngchaos.com/
> Earth: "Mostly harmless"
> - revised entry in the HitchHiker's Guide to the Galaxy
