[Qgis-user] QGIS installation problem with Mac OSX 10.8.4 and some Qt4 Modules
William Kyngesburye
woklist at kyngchaos.com
Sun Jul 7 09:13:28 PDT 2013
This is very puzzling. I don't have anything in /usr/local that would confuse my configure, so I temporarily installed GSL in /usr/local (simple to uninstall), it still found my GSL framework.
But, looking closer at your configure results, I see that some things are automatically found in /usr/local/cellar, which is not a standard search path. So there is something telling cmake additional search paths and overriding default cmake behavior. Maybe an environment setting? Did you add any exports to your ~/.bash_profile? If not, maybe homebrew did automatically?
env will show all current environment settings, see if there is something related to cmake, maybe in the PATH, or DYLD_LIBRARY_PATH or DYLD_FRAMEWORK_PATH, or some other system search path variable.
On Jul 7, 2013, at 10:48 AM, Marcel Stadelmann wrote:
> I used cmake version 2.8.11.1 until yesterday, now i installed the version 2.8.11.2 but still the same error for SPATIALITE_LIBRARY appear. GDAL frameworks are now found without explicitly set a cmake variable.
> Am 07.07.2013 um 01:33 schrieb William Kyngesburye <woklist at kyngchaos.com>:
>> Current stable was 2.8.11 (what I have) until a few days ago. 2.8.11.2 was released Jul 3. I don't see any changes in the latest release or in master that might cause this behavior. 2.8.11.2 still works for me, but I don't have anything in /usr/local that would confuse it.
>> On Jul 6, 2013, at 6:00 PM, Marcel Stadelmann wrote:
>>> Am 07.07.2013 um 00:53 schrieb William Kyngesburye <woklist at kyngchaos.com>:
>>>> This is very strange, cmake should be finding all the frameworks (GEOS, PROJ, SQLite/Spatialite) and not other libraries. You have to explicitly set a cmake variable so it doesn't prefer frameworks over libraries.
>>>> Maybe cmake is misbehaving - what is your cmake version?
>>> where can I check the cmake version? I downloaded the master branch just a few hours ago.
>>>> On Jul 6, 2013, at 5:33 PM, Marcel Stadelmann wrote:
>>>>> I use Xcode 4.6.3
>>>>> Cmake QGIS didn't work. First GDAL was not found. After including -D GDAL_CONFIG=/Library/Frameworks/GDAL.framework/Versions/1.10/unix/bin/gdal-config it was found, but other errors occurred (see below). What could it be?
>>>>> Marcels-iMac:build Marcello$ cmake -D CMAKE_INSTALL_PREFIX=~/Applications \
>>>>>> -D CMAKE_BUILD_TYPE=MINSIZEREL -D ENABLE_TESTS=FALSE \
>>>>>> -D WITH_INTERNAL_SPATIALITE=FALSE -D WITH_PYSPATIALITE=FALSE \
>>>>>> -D SPATIALINDEX_LIBRARY=/usr/local/lib/libspatialindex.dylib \
>>>>>> -D SPATIALINDEX_INCLUDE_DIR=/usr/local/include/spatialindex \
>>>>>> -D QWT_LIBRARY=/usr/local/qwt-6.0.2/lib/libqwt.dylib \
>>>>>> -D QWT_INCLUDE_DIR=/usr/local/qwt-6.0.2/include \
>>>>>> -D BISON_EXECUTABLE=/usr/local/bin/bison \
>>>>>> -D GDAL_CONFIG=/Library/Frameworks/GDAL.framework/Versions/1.10/unix/bin/gdal-config \
>>>>> -- QGIS version: 1.9.0 Master (10900)
>>>>> -- Found GRASS: /Applications/GRASS-6.4.app/Contents/MacOS (6.4.2)
>>>>> -- Found Proj: /usr/local/lib/libproj.dylib
>>>>> -- Found GEOS: /usr/local/Cellar/geos/3.3.8/lib/libgeos_c.dylib
>>>>> -- Found GDAL: /Library/Frameworks/GDAL.framework/Versions/1.10/unix/lib/libgdal.dylib (1.10.0)
>>>>> -- Found Expat: /usr/local/lib/libexpat.dylib
>>>>> -- Found Spatialindex: /usr/local/lib/libspatialindex.dylib
>>>>> -- Found Qwt: /usr/local/qwt-6.0.2/lib/libqwt.dylib (6.0.2)
>>>>> -- Found Sqlite3: /usr/lib/libsqlite3.dylib
>>>>> -- Found PostgreSQL: /usr/local/pgsql-9.2/lib/libpq.dylib
>>>>> -- Touch support disabled
>>>>> -- Found QScintilla2: /usr/local/lib/libqscintilla2.dylib (2.7.2)
>>>>> -- Pedantic compiler settings enabled
>>>>> -- Found Python executable: /usr/bin/python
>>>>> -- Found Python version: 2.7.2
>>>>> -- Found Python library: -framework Python
>>>>> -- Found SIP version: 4.14.6
>>>>> -- Found PyQt4 version: 4.10.2
>>>>> -- Found QScintilla2 PyQt4 module: 2.7.2
>>>>> fatal: Not a git repository (or any of the parent directories): .git
>>>>> -- Found GSL: -L/usr/local/Cellar/gsl/1.15/lib -lgsl -lgslcblas
>>>>> -- txt2tags not found - disabled
>>>>> CMake Error: The following variables are used in this project, but they are set to NOTFOUND.
>>>>> Please set them or make sure they are set and tested correctly in the CMake files:
>>>>> SPATIALITE_LIBRARY
>>>>> linked by target "qgis_core" in directory /Users/Marcello/Downloads/Quantum-GIS-master/src/core
>>>>> linked by target "offlineeditingplugin" in directory /Users/Marcello/Downloads/Quantum-GIS-master/src/plugins/offline_editing
>>>>> -- Configuring incomplete, errors occurred!
>> William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
>> http://www.kyngchaos.com/
>> Earth: "Mostly harmless"
>> - revised entry in the HitchHiker's Guide to the Galaxy
> Qgis-user mailing list
"The beast is actively interested only in now, and, as it is always now and always shall be, there is an eternity of time for the accomplishment of objects."
- the wisdom of Tarzan
