[Qgis-user] where to install qgis-web-client on Mac OSX 10.8.4
    Marcel Stadelmann
    marcel.stadelmann at gmx.net
    Tue Jul  9 08:59:39 PDT 2013
Where can I see the path to QGIS WMS Server directory? I don't know where to save the *.qgs files, so that the QGIS server can find it.
Thanks and regards,
Marcel
Am 09.07.2013 um 16:36 schrieb Marcel Stadelmann <marcel.stadelmann at gmx.net>:
> Hi Bernhard,
> Thanks for the answers.
> Am 09.07.2013 um 15:20 schrieb Bernhard Ströbl <bernhard.stroebl at jena.de>:
>> Hi Marcel,
>> the way to call your QGIS server is something like:
>> http://localhost/qgis-mapserv/qgis_mapserv.fcgi?map=<path_to_your_map>/yourmap.qgs?REQUEST=GetCapabilities&SERVICE=WMS&VERSION=1.3
>> to get the server's capabilites
>> be sure to know the possible requests a WMS server can reply to, see e.g. [1]
>> The client accesses the server and not vice versa.
> Ok, I think I understand the philosophy.
>> Steps to do:
>> 1) Install QGIS server (done)
>> 2) Feed QGIS server with a qgis project (*.qgs file)
> I saved a QGIS test project with wms capabilites under /Users/Marcello/Downloads/test/alaska.qgs
> The reply of http://localhost/qgis-mapserv/qgis_mapserv.fcgi?map=/Users/Marcello/Downloads/test/alaska.qgs&SERVICE=WMS&REQUEST=GetCapabilities in Safari is:
> Configuration file problem : perhaps you left off the .qgs extension?
> Does the project path need special permissions?
>> 3) access QGIS server from a WMS client (e.g. QGIS desktop) to verify it is running and delivers maps.
> Isn't it easier to test this with Safari? In QGIS I tried to load the alaska layer through "add wms-layer". But i couldn't connect to my localhost. I don't know what url exactly is needed. I tried with http://localhost/Users/Marcello/Downloads/test/alaska.qgs but its not working. The message was:
> Antwort nicht verstanden. Der wms-Provider sagte:
> Eigenschaften-Abfrage gescheitert: Error downloading http://localhost/Users/Marcello/Downloads/test/alaska.qgs?SERVICE=WMS&REQUEST=GetCapabilities - server replied: Not Found
>> 4) install and configure QWC, see [2]
> Where are this kind of projects normally saved in OSX? I think the QWC files needs to be saved in the project file (in my case under /Users/Marcello/Downloads/test)?
>> Bernhard
>> [1] http://en.wikipedia.org/wiki/Web_Map_Service
>> [2]https://github.com/qgis/qgis-web-client
>> Am 09.07.2013 13:24, schrieb Marcel Stadelmann:
>>> Hi Bernhard,
>>> Thank you for answering. On my Mac the Apache server works. The QGIS
>>> Server is installed according the Tutorial
>>> http://hub.qgis.org/projects/quantum-gis/wiki/QGIS_Server_Tutorial. It
>>> also seems to work. When I open the link
>>> http://localhost/qgis-mapserv/qgis_mapserv.fcgi? I get the following
>>> message from Safari: Please check the value of the REQUEST parameter.
>>> Now I try to configure and publish a simple QGIS project. But I don't
>>> know where to put the files. I also don't understand how the QGIS Server
>>> finds the path to the Web Client, because at the moment I have the
>>> qgis-web-client folder in /Users/Marcello/Downloads.
>>> Marcel
>>> Am 09.07.2013 um 12:52 schrieb Bernhard Ströbl <bernhard.stroebl at jena.de
>>> <mailto:bernhard.stroebl at jena.de>>:
>>>> Hi Marcel,
>>>> I am sorry, I do not really understand your question, so I explain
>>>> some things, maybe you can reformulate your question and people with
>>>> Mac OSX knowledge can help you then.
>>>> qgis-web-client (QWC) is a JavaScript program to be run in a browser.
>>>> To deliver QWC to the browser of your clients you need a web server
>>>> (e.g. Apache). You can put QWC whereeever your web server can access
>>>> it. QWC needs QGIS Server (a WMS server), normally you would run QGIS
>>>> server on the same machine.
>>>> Bernhard
>>>> Am 09.07.2013 11:18, schrieb Marcel Stadelmann:
>>>>> Hi all,
>>>>> I try to install the qgis-web-client on a Mac OSX 10.8.4. But I don't
>>>>> understand where exactly I have to put it? I think the
>>>>> "/home/web/qgis-web-client" path is not for OSX?
>>>>> regards,
>>>>> Marcel
>> __________ Information from ESET Mail Security, version of virus signature database 8545 (20130709) __________
>> The message was checked by ESET Mail Security.
>> http://www.eset.com
>> Qgis-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20130709/f59bad0d/attachment.html>
