[Qgis-user] where to install qgis-web-client on Mac OSX 10.8.4
Marcel Stadelmann
marcel.stadelmann at gmx.net
Tue Jul 9 10:21:49 PDT 2013
Sorry, I don't get it.
I can connect form QGIS Desktop as a WMS-Client to QGIS Server, but the Layers don't appear.
Does somebody know a step by step instruction how to configure a simple example on OSX?
Thanks and regards,
Marcel
Am 09.07.2013 um 18:11 schrieb Bernhard Ströbl <bernhard.stroebl at jena.de>:
> anywhere you like and Apache can access them (on a Linux system file permissions must match, I put them in a subdirectory of /srv/www)
> Bernhard
> Am 09.07.2013 17:59, schrieb Marcel Stadelmann:
>> Where can I see the path to QGIS WMS Server directory? I don't know
>> where to save the *.qgs files, so that the QGIS server can find it.
>> Thanks and regards,
>> Marcel
>> Am 09.07.2013 um 16:36 schrieb Marcel Stadelmann
>> <marcel.stadelmann at gmx.net <mailto:marcel.stadelmann at gmx.net>>:
>>> Hi Bernhard,
>>> Thanks for the answers.
>>> Am 09.07.2013 um 15:20 schrieb Bernhard Ströbl
>>> <bernhard.stroebl at jena.de <mailto:bernhard.stroebl at jena.de>>:
>>>> Hi Marcel,
>>>> the way to call your QGIS server is something like:
>>>> http://localhost/qgis-mapserv/qgis_mapserv.fcgi?map=<path_to_your_map>/yourmap.qgs?REQUEST=GetCapabilities&SERVICE=WMS&VERSION=1.3
>>>> <http://localhost/qgis-mapserv/qgis_mapserv.fcgi?map=%3Cpath_to_your_map%3E/yourmap.qgs?REQUEST=GetCapabilities&SERVICE=WMS&VERSION=1.3>
>>>> to get the server's capabilites
>>>> be sure to know the possible requests a WMS server can reply to, see
>>>> e.g. [1]
>>>> The client accesses the server and not vice versa.
>>> Ok, I think I understand the philosophy.
>>>> Steps to do:
>>>> 1) Install QGIS server (done)
>>>> 2) Feed QGIS server with a qgis project (*.qgs file)
>>> I saved a QGIS test project with wms capabilites under
>>> /Users/Marcello/Downloads/test/alaska.qgs
>>> The reply of
>>> http://localhost/qgis-mapserv/qgis_mapserv.fcgi?map=/Users/Marcello/Downloads/test/alaska.qgs&SERVICE=WMS&REQUEST=GetCapabilities
>>> <http://localhost/qgis-mapserv/qgis_mapserv.fcgi?map=/Users/Marcello/Downloads/test/alaska.qgs&SERVICE=WMS&REQUEST=GetCapabilities>
>>> in Safari is:
>>> Configuration file problem : perhaps you left off the .qgs extension?
>>> Does the project path need special permissions?
>>>> 3) access QGIS server from a WMS client (e.g. QGIS desktop) to verify
>>>> it is running and delivers maps.
>>> Isn't it easier to test this with Safari? In QGIS I tried to load the
>>> alaska layer through "add wms-layer". But i couldn't connect to my
>>> localhost. I don't know what url exactly is needed. I tried with
>>> http://localhost/Users/Marcello/Downloads/test/alaska.qgs but its not
>>> working. The message was:
>>> Antwort nicht verstanden. Der wms-Provider sagte:
>>> Eigenschaften-Abfrage gescheitert: Error downloading
>>> http://localhost/Users/Marcello/Downloads/test/alaska.qgs?SERVICE=WMS&REQUEST=GetCapabilities
>>> <http://localhost/Users/Marcello/Downloads/test/alaska.qgs?SERVICE=WMS&REQUEST=GetCapabilities>
>>> - server replied: Not Found
>>>> 4) install and configure QWC, see [2]
>>> Where are this kind of projects normally saved in OSX? I think the QWC
>>> files needs to be saved in the project file (in my case under
>>> /Users/Marcello/Downloads/test)?
>>>> Bernhard
>>>> [1] http://en.wikipedia.org/wiki/Web_Map_Service
>>>> [2]https://github.com/qgis/qgis-web-client
>>>> Am 09.07.2013 13:24, schrieb Marcel Stadelmann:
>>>>> Hi Bernhard,
>>>>> Thank you for answering. On my Mac the Apache server works. The QGIS
>>>>> Server is installed according the Tutorial
>>>>> http://hub.qgis.org/projects/quantum-gis/wiki/QGIS_Server_Tutorial. It
>>>>> also seems to work. When I open the link
>>>>> http://localhost/qgis-mapserv/qgis_mapserv.fcgi? I get the following
>>>>> message from Safari: Please check the value of the REQUEST parameter.
>>>>> Now I try to configure and publish a simple QGIS project. But I don't
>>>>> know where to put the files. I also don't understand how the QGIS Server
>>>>> finds the path to the Web Client, because at the moment I have the
>>>>> qgis-web-client folder in /Users/Marcello/Downloads.
>>>>> Marcel
>>>>> Am 09.07.2013 um 12:52 schrieb Bernhard Ströbl
>>>>>> Hi Marcel,
>>>>>> I am sorry, I do not really understand your question, so I explain
>>>>>> some things, maybe you can reformulate your question and people with
>>>>>> Mac OSX knowledge can help you then.
>>>>>> qgis-web-client (QWC) is a JavaScript program to be run in a browser.
>>>>>> To deliver QWC to the browser of your clients you need a web server
>>>>>> (e.g. Apache). You can put QWC whereeever your web server can access
>>>>>> it. QWC needs QGIS Server (a WMS server), normally you would run QGIS
>>>>>> server on the same machine.
>>>>>> Bernhard
>>>>>> Am 09.07.2013 11:18, schrieb Marcel Stadelmann:
>>>>>>> Hi all,
>>>>>>> I try to install the qgis-web-client on a Mac OSX 10.8.4. But I don't
>>>>>>> understand where exactly I have to put it? I think the
>>>>>>> "/home/web/qgis-web-client" path is not for OSX?
>>>>>>> regards,
>>>>>>> Marcel
>>>> __________ Information from ESET Mail Security, version of virus
>>>> signature database 8545 (20130709) __________
>>>> The message was checked by ESET Mail Security.
>>>> http://www.eset.com <http://www.eset.com/>
>>>> _______________________________________________
>>>> Qgis-user mailing list
>>>> Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
>>>> http://lists.osgeo.org/mailman/listinfo/qgis-user
>> signature database 8546 (20130709) __________
>> http://www.eset.com
>> __________ Information from ESET Mail Security, version of virus signature database 8546 (20130709) __________
>> http://www.eset.com
> http://www.eset.com
