[Qgis-user] where to install qgis-web-client on Mac OSX 10.8.4
Andreas Neumann
a.neumann at carto.net
Wed Jul 10 05:34:16 PDT 2013
Marcel,
Do you mean the layers don't appear in QGIS or in QGIS web client? This
is an important distinction.
The first means that QGIS server is not installed and configured
correctly, the other means that QGIS server is running ok and you have a
web client configuration problem.
I know - the getting started it is a bit hard, esp. if you are on OSX or
Windows where there are fewer users. Most existing users install and run
QGIS server on Linux.
Andreas
Am 09.07.2013 19:21, schrieb Marcel Stadelmann:
> Sorry, I don't get it.
> I can connect form QGIS Desktop as a WMS-Client to QGIS Server, but the Layers don't appear.
> Does somebody know a step by step instruction how to configure a simple example on OSX?
> Thanks and regards,
> Marcel
> Am 09.07.2013 um 18:11 schrieb Bernhard Ströbl <bernhard.stroebl at jena.de>:
>> anywhere you like and Apache can access them (on a Linux system file permissions must match, I put them in a subdirectory of /srv/www)
>> Bernhard
>> Am 09.07.2013 17:59, schrieb Marcel Stadelmann:
>>> Where can I see the path to QGIS WMS Server directory? I don't know
>>> where to save the *.qgs files, so that the QGIS server can find it.
>>> Thanks and regards,
>>> Marcel
>>> Am 09.07.2013 um 16:36 schrieb Marcel Stadelmann
>>> <marcel.stadelmann at gmx.net <mailto:marcel.stadelmann at gmx.net>>:
>>>> Hi Bernhard,
>>>> Thanks for the answers.
>>>> Am 09.07.2013 um 15:20 schrieb Bernhard Ströbl
>>>> <bernhard.stroebl at jena.de <mailto:bernhard.stroebl at jena.de>>:
>>>>> Hi Marcel,
>>>>> the way to call your QGIS server is something like:
>>>>> http://localhost/qgis-mapserv/qgis_mapserv.fcgi?map=<path_to_your_map>/yourmap.qgs?REQUEST=GetCapabilities&SERVICE=WMS&VERSION=1.3
>>>>> <http://localhost/qgis-mapserv/qgis_mapserv.fcgi?map=%3Cpath_to_your_map%3E/yourmap.qgs?REQUEST=GetCapabilities&SERVICE=WMS&VERSION=1.3>
>>>>> to get the server's capabilites
>>>>> be sure to know the possible requests a WMS server can reply to, see
>>>>> e.g. [1]
>>>>> The client accesses the server and not vice versa.
>>>> Ok, I think I understand the philosophy.
>>>>> Steps to do:
>>>>> 1) Install QGIS server (done)
>>>>> 2) Feed QGIS server with a qgis project (*.qgs file)
>>>> I saved a QGIS test project with wms capabilites under
>>>> /Users/Marcello/Downloads/test/alaska.qgs
>>>> The reply of
>>>> http://localhost/qgis-mapserv/qgis_mapserv.fcgi?map=/Users/Marcello/Downloads/test/alaska.qgs&SERVICE=WMS&REQUEST=GetCapabilities
>>>> <http://localhost/qgis-mapserv/qgis_mapserv.fcgi?map=/Users/Marcello/Downloads/test/alaska.qgs&SERVICE=WMS&REQUEST=GetCapabilities>
>>>> in Safari is:
>>>> Configuration file problem : perhaps you left off the .qgs extension?
>>>> Does the project path need special permissions?
>>>>> 3) access QGIS server from a WMS client (e.g. QGIS desktop) to verify
>>>>> it is running and delivers maps.
>>>> Isn't it easier to test this with Safari? In QGIS I tried to load the
>>>> alaska layer through "add wms-layer". But i couldn't connect to my
>>>> localhost. I don't know what url exactly is needed. I tried with
>>>> http://localhost/Users/Marcello/Downloads/test/alaska.qgs but its not
>>>> working. The message was:
>>>> Antwort nicht verstanden. Der wms-Provider sagte:
>>>> Eigenschaften-Abfrage gescheitert: Error downloading
>>>> http://localhost/Users/Marcello/Downloads/test/alaska.qgs?SERVICE=WMS&REQUEST=GetCapabilities
>>>> <http://localhost/Users/Marcello/Downloads/test/alaska.qgs?SERVICE=WMS&REQUEST=GetCapabilities>
>>>> - server replied: Not Found
>>>>> 4) install and configure QWC, see [2]
>>>> Where are this kind of projects normally saved in OSX? I think the QWC
>>>> files needs to be saved in the project file (in my case under
>>>> /Users/Marcello/Downloads/test)?
>>>>> Bernhard
>>>>> [1] http://en.wikipedia.org/wiki/Web_Map_Service
>>>>> [2]https://github.com/qgis/qgis-web-client
>>>>> Am 09.07.2013 13:24, schrieb Marcel Stadelmann:
>>>>>> Hi Bernhard,
>>>>>> Thank you for answering. On my Mac the Apache server works. The QGIS
>>>>>> Server is installed according the Tutorial
>>>>>> http://hub.qgis.org/projects/quantum-gis/wiki/QGIS_Server_Tutorial. It
>>>>>> also seems to work. When I open the link
>>>>>> http://localhost/qgis-mapserv/qgis_mapserv.fcgi? I get the following
>>>>>> message from Safari: Please check the value of the REQUEST parameter.
>>>>>> Now I try to configure and publish a simple QGIS project. But I don't
>>>>>> know where to put the files. I also don't understand how the QGIS Server
>>>>>> finds the path to the Web Client, because at the moment I have the
>>>>>> qgis-web-client folder in /Users/Marcello/Downloads.
>>>>>> Marcel
>>>>>> Am 09.07.2013 um 12:52 schrieb Bernhard Ströbl
>>>>>>> Hi Marcel,
>>>>>>> I am sorry, I do not really understand your question, so I explain
>>>>>>> some things, maybe you can reformulate your question and people with
>>>>>>> Mac OSX knowledge can help you then.
>>>>>>> qgis-web-client (QWC) is a JavaScript program to be run in a browser.
>>>>>>> To deliver QWC to the browser of your clients you need a web server
>>>>>>> (e.g. Apache). You can put QWC whereeever your web server can access
>>>>>>> it. QWC needs QGIS Server (a WMS server), normally you would run QGIS
>>>>>>> server on the same machine.
>>>>>>> Bernhard
>>>>>>> Am 09.07.2013 11:18, schrieb Marcel Stadelmann:
>>>>>>>> Hi all,
>>>>>>>> I try to install the qgis-web-client on a Mac OSX 10.8.4. But I don't
>>>>>>>> understand where exactly I have to put it? I think the
>>>>>>>> "/home/web/qgis-web-client" path is not for OSX?
>>>>>>>> regards,
>>>>>>>> Marcel
>>>>> __________ Information from ESET Mail Security, version of virus
>>>>> signature database 8545 (20130709) __________
>>>>> The message was checked by ESET Mail Security.
>>>>> http://www.eset.com <http://www.eset.com/>
>>>>> _______________________________________________
>>>>> Qgis-user mailing list
>>>>> Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
>>>>> http://lists.osgeo.org/mailman/listinfo/qgis-user
>>> signature database 8546 (20130709) __________
>>> http://www.eset.com
>>> __________ Information from ESET Mail Security, version of virus signature database 8546 (20130709) __________
>>> http://www.eset.com
>> http://www.eset.com
