[Qgis-user] Qgis-user Digest, Vol 89, Issue 61
Wilkes, Becky
bwilkes at email.unc.edu
Thu Jul 11 08:16:52 PDT 2013
I, too, recently subscribed to this list, but with the setting "daily digest". I am instead getting multiple digests each day, for a total of about 6-8 emails (3-4 messages within each email) per day. Anyone know how to fix this setting?
Becky Wilkes
-----Original Message-----
From: qgis-user-bounces at lists.osgeo.org [mailto:qgis-user-bounces at lists.osgeo.org] On Behalf Of qgis-user-request at lists.osgeo.org
Sent: Thursday, July 11, 2013 11:07 AM
To: qgis-user at lists.osgeo.org
Subject: Qgis-user Digest, Vol 89, Issue 61
Send Qgis-user mailing list submissions to
To subscribe or unsubscribe via the World Wide Web, visit
http://lists.osgeo.org/mailman/listinfo/qgis-user
or, via email, send a message with subject or body 'help' to
You can reach the person managing the list at
qgis-user-owner at lists.osgeo.org
When replying, please edit your Subject line so it is more specific than "Re: Contents of Qgis-user digest..."
Today's Topics:
1. Re: Emails! (Peter Sch?rch)
2. Re: where to install qgis-web-client on Mac OSX 10.8.4
(Bernhard Str?bl)
3. Re: where to install qgis-web-client on Mac OSX 10.8.4
(Marcel Stadelmann)
Message: 1
Date: Thu, 11 Jul 2013 11:31:39 +0200
From: Peter Sch?rch <p.schuerch at meierpartner.ch>
To: "Timothy Griffiths" <timothy.griffiths at tgriffiths65.plus.com>,
<Qgis-user at lists.osgeo.org>
Subject: Re: [Qgis-user] Emails!
Message-ID:
<3266F9F673EFF44BB345D5A707E32AC28836BE at meiwed1.meierpartner.local>
Content-Type: text/plain; charset="iso-8859-1"
This is a mailing list. It is supposed to distribute emails. If you don't like it resign from the list or filter them in a separate folder.
Cheers, Peter
-----Urspr?ngliche Nachricht-----
Von: qgis-user-bounces at lists.osgeo.org [mailto:qgis-user-bounces at lists.osgeo.org] Im Auftrag von Timothy Griffiths
Gesendet: Mittwoch, 10. Juli 2013 10:46
An: Qgis-user at lists.osgeo.org
Betreff: [Qgis-user] Emails!
Dear Sirs
Help, I really want to learn Qgis, but I'm drowning in emails, why?
Tim G
Message: 2
Date: Thu, 11 Jul 2013 11:45:04 +0200
From: Bernhard Str?bl <bernhard.stroebl at jena.de>
Subject: Re: [Qgis-user] where to install qgis-web-client on Mac OSX
10.8.4
Message-ID: <51DE7EA0.1090805 at jena.de>
Content-Type: text/plain; charset=windows-1252; format=flowed
Hi Marcel,
comment below
Am 11.07.2013 11:31, schrieb Marcel Stadelmann:
> Hi Bernhard, Andreas,
> Now in QGIS it works, but not in the browser (see below).
congrats you mastered the first step
> Following I describe what I did to test if the QGIS Server is running,
> so maybe somebody else can learn from it. I know it's quite basic, but
> in the beginning it may help. I think in my case, it was a path problem.
> 1. Copy the alaska.shp (+ prj, dbf, shx) to
> /Library/WebServer/Documents/ (This is the Web root with Admin rights)
> 2. In QGIS save a project according the QGIS User Manual 1.8 Chapter
> QGIS Server in /Library/WebServer/Documents/ 3. Make sure when reopen
> the QGIS project from /Library/WebServer/Documents/ it finds still all
> the layers. (One of my mistakes was, that I moved the project file
> afterwards into this folder and QGIS couldn't find anymore the
> alaska.shp file. I thought the layer paths are absolute, but they are
> not.)
this is in fact controlled by project settings
> 4. Open a new project and set the crs (i.e. EPSG:2964). Then add a
> wms-layer.
> 5. Connect to localhost with the following url:
> http://localhost/qgis-mapserv/qgis_mapserv.fcgi?map=/Library/WebServer
> /Documents/alaska.qgs 6. 3 layers appear, add the first one.
> 7. Verify the data are shown.
> Am 11.07.2013 um 08:09 schrieb Bernhard Str?bl
> <mailto:bernhard.stroebl at jena.de>>:
>> Hi Marcel,
>> I guess now it is time to check for correctness of the srs.
>> Which srs is the alaska project and data in? Is it EPSG:2964 as your
>> GetMap request suggests?
>> Take the GetMap-url and enter it in the browser. Do you get an error
>> message or a white image? If you get a white image than there is no
>> data in the bounding box for which you request your image.
> The url:
> /Documents/alaska.qgs&SERVICE=WMS&REQUEST=GetMap
> <http://localhost/qgis-mapserv/qgis_mapserv.fcgi?map=/Library/WebServe
> r/Documents/alaska.qgs&SERVICE=WMS&REQUEST=GetMap>
> gives this error massage:
> Output format '' is not supported in the GetMap request
> What could cause this message?
You left out the format-parameter. I suggest you learn which parameters a GetMap request needs and which are optional. A good starting point would be your server's log file. See how the GetMap requests QGIS desktop issues look like. Try one of those in your browser and play with the paramters.
Bernahrd
>> Make sure to use the same srs in
>> 1) the server project
>> 2) the data being served with that project
>> 3) your client project (i.e. the project in QGIS desktop you are
>> trying to load maps into)
> I made sure that CRS is everywhere EPSG:2964, but it was not the problem.
>> Bernhard
>> Am 10.07.2013 21:59, schrieb Marcel Stadelmann:
>>> Hi Andreas,
>>> yes, with the map parameter I could go a step further, the alaska
>>> layer appeared. But while trying to import it, the following
>>> internal server error was shown:
>>> Kartenabfrage-Fehler [Fehler:Error downloading
>>> er/Documents/alaska.qgs&&SERVICE=WMS&VERSION=1.3.0&REQUEST=GetMap&BB
>>> OX=-15256791.5967269185930490,482471.5356363095343113,15452694.48982
>>> 76831954718,30602207.0081926248967648&CRS=EPSG:2964&WIDTH=1084&HEIGH
>>> T=1063&LAYERS=alaska&STYLES=&FORMAT=image/jpeg&DPI=72&MAP_RESOLUTION
>>> =72&FORMAT_OPTIONS=dpi:72
>>> ver/Documents/alaska.qgs&&SERVICE=WMS&VERSION=1.3.0&REQUEST=GetMap&B
>>> BOX=-15256791.5967269185930490,482471.5356363095343113,15452694.4898
>>> 276831954718,30602207.0081926248967648&CRS=EPSG:2964&WIDTH=1084&HEIG
>>> HT=1063&LAYERS=alaska&STYLES=&FORMAT=image/jpeg&DPI=72&MAP_RESOLUTIO
>>> N=72&FORMAT_OPTIONS=dpi:72>
>>> - server replied: Internal Server Error; URL:
>>> =72&FORMAT_OPTIONS=dpi:72]
>>> N=72&FORMAT_OPTIONS=dpi:72]>
>>> The layer was somehow imported, i.e. i can open the preferences, but
>>> no data are shown.
>>> Any idea?
>>> Thank you
>>> Marcel
>>> Am 10.07.2013 um 21:15 schrieb Andreas Neumann<a.neumann at carto.net
>>> <mailto:a.neumann at carto.net>>:
>>>> Hi Marcel,
>>>> You are missing the project file. Did you read the QGIS server tutorial?
>>>> See
>>>> http://hub.qgis.org/projects/quantum-gis/wiki/QGIS_Server_Tutorial#
>>>> Map-parameter
>>>> Otherwise the server can't know what project you want to access.
>>>> First you should start with a map parameter - later on, esp. in a
>>>> production environment - you should configure Apache rewriting.
>>>> I don't think that OSX is too different from Linux - it least it is
>>>> more similar than Windows.
>>>> Andreas
>>>> Am 10.07.2013 18:33, schrieb Marcel Stadelmann:
>>>>> Am 10.07.2013 um 16:58 schrieb Andreas Neumann<a.neumann at carto.net>:
>>>>>> Hi Marcel,
>>>>>> If the GetCapabilities command is answering it means that at
>>>>>> least parts of the QGIS server is running ok.
>>>>>> The WMS server supports the following commands:
>>>>>> GetCapabilities
>>>>>> GetMap
>>>>>> GetLegendGraphic
>>>>>> GetFeatureInfo
>>>>>> GetPrint
>>>>>> The GetCapabilities is always at the start of a session or
>>>>>> connection to get the service metadata.
>>>>>> In your case it looks like a CRS issue. You should make sure that
>>>>>> in your new empty test project you specify the same projection as
>>>>>> in the Alaska sample project. There are reprojection options -
>>>>>> but for a start it is easier if server and client are in the same
>>>>>> projection. It will also be faster if no reprojection has to be
>>>>>> done.
>>>>> I tried, but no success. After I delete the
>>>>> /Library/WebServer/Documents/alaska.qgs file, still 1 layer was
>>>>> showing up while adding a WMS-Layer. It means the behaviour of the
>>>>> WMS-Connection is the same with or without the project file
>>>>> alaska.qgs. So, it's probably not a CRS issue. It seems that the
>>>>> QGIS Server doesn't see the alaska project file at all.
>>>>> I connect to the localhost with the url
>>>>> http://localhost/qgis-mapserv/qgis_mapserv.fcgi? -> Is this correct?
>>>>> In the QGIS user manual (Chapter QGIS Server) it says that a copy
>>>>> of qgis_mapserv.fcgi is needed for Linux. But how is it for an OSX?
>>>>> I found this file in
>>>>> /Applications/QGIS.app/Contents/MacOS/fcgi-bin/ and put also a
>>>>> copy of it in /Library/WebServer/Documents/. But somehow I don't
>>>>> understand how it works? I afraid my QGIS Server configuration is
>>>>> not correct. But at this point I'm lost.
>>>>> Is there somewhere a documentation for OSX that explains which
>>>>> file has to be in which folder?
>>>>>> Once QGIS works fine as a client, you can go on and configure
>>>>>> QGIS web client. Before, it makes no sense and you should first fix the server.
>>>>>> Andreas
>>>>>> Am 10.07.2013 16:34, schrieb Marcel Stadelmann:
>>>>>>> Hello Andreas,
>>>>>>> I try to do the Alaska example described in the QGIS
>>>>>>> Documentation, chapter QGIS Server
>>>>>>> (http://docs.qgis.org/1.8/html/de/docs/user_manual/working_with_ogc/ogc_server_support.html).
>>>>>>> The problem is, that this example is for Linux. On OSX some
>>>>>>> things seem to be a bit different, especially the paths. I saved
>>>>>>> the project file with the new project settings in
>>>>>>> /Library/WebServer/Documents/alaska.qgs.
>>>>>>> In order to test if my QGIS server is running ok, I did two tests:
>>>>>>> 1. In Safari I put the following url:
>>>>>>> Server/Documents/alaska.qgs&SERVICE=WMS&REQUEST=GetCapabilities
>>>>>>> the browser answers with the following message:
>>>>>>> WMS Test test text/xml image/jpeg image/png image/png;
>>>>>>> mode=16bit image/png; mode=8bit image/png; mode=1bit text/plain
>>>>>>> text/html text/xml image/jpeg image/png text/xml svg png pdf
>>>>>>> text/xml alaska -179.843 178.454 48.0545 72.2621
>>>>>>> I thought this means the server is running. No map is shown
>>>>>>> because I still haven't installed the QGIS client. So far so good.
>>>>>>> 2. In QGIS I wanted to add a WMS-Layer. I connected to the
>>>>>>> It shows up 1 layer with ID 0 and name wfslayer, but nothing
>>>>>>> more. When I select this layer, it is not possible to import it.
>>>>>>> It says: Kein gemeinsames KBS f?r gew?hlte Layer. So, I don't
>>>>>>> know if my QGIS Server is running ok.
>>>>>>> Marcel
>>>>>>> Am 10.07.2013 um 14:34 schrieb Andreas Neumann<a.neumann at carto.net>:
>>>>>>>> Marcel,
>>>>>>>> Do you mean the layers don't appear in QGIS or in QGIS web
>>>>>>>> client? This is an important distinction.
>>>>>>>> The first means that QGIS server is not installed and
>>>>>>>> configured correctly, the other means that QGIS server is
>>>>>>>> running ok and you have a web client configuration problem.
>>>>>>>> I know - the getting started it is a bit hard, esp. if you are
>>>>>>>> on OSX or Windows where there are fewer users. Most existing
>>>>>>>> users install and run QGIS server on Linux.
>>>>>>>> Andreas
>>>>>>>> Am 09.07.2013 19:21, schrieb Marcel Stadelmann:
>>>>>>>>> Sorry, I don't get it.
>>>>>>>>> I can connect form QGIS Desktop as a WMS-Client to QGIS
>>>>>>>>> Server, but the Layers don't appear.
>>>>>>>>> Does somebody know a step by step instruction how to configure
>>>>>>>>> a simple example on OSX?
>>>>>>>>> Thanks and regards,
>>>>>>>>> Marcel
>>>>>>>>> Am 09.07.2013 um 18:11 schrieb Bernhard
>>>>>>>>> Str?bl<bernhard.stroebl at jena.de>:
>>>>>>>>>> anywhere you like and Apache can access them (on a Linux
>>>>>>>>>> system file permissions must match, I put them in a
>>>>>>>>>> subdirectory of /srv/www)
>>>>>>>>>> Bernhard
>>>>>>>>>> Am 09.07.2013 17:59, schrieb Marcel Stadelmann:
>>>>>>>>>>> Where can I see the path to QGIS WMS Server directory? I
>>>>>>>>>>> don't know where to save the *.qgs files, so that the QGIS
>>>>>>>>>>> server can find it.
>>>>>>>>>>> Thanks and regards,
>>>>>>>>>>> Marcel
>>>>>>>>>>> Am 09.07.2013 um 16:36 schrieb Marcel Stadelmann
>>>>>>>>>>> <marcel.stadelmann at gmx.net<mailto:marcel.stadelmann at gmx.net>>:
>>>>>>>>>>>> Hi Bernhard,
>>>>>>>>>>>> Thanks for the answers.
>>>>>>>>>>>> Am 09.07.2013 um 15:20 schrieb Bernhard Str?bl
>>>>>>>>>>>> <bernhard.stroebl at jena.de<mailto:bernhard.stroebl at jena.de>>:
>>>>>>>>>>>>> Hi Marcel,
>>>>>>>>>>>>> the way to call your QGIS server is something like:
>>>>>>>>>>>>> http://localhost/qgis-mapserv/qgis_mapserv.fcgi?map=<path_
>>>>>>>>>>>>> to_your_map>/yourmap.qgs?REQUEST=GetCapabilities&SERVICE=W
>>>>>>>>>>>>> MS&VERSION=1.3
>>>>>>>>>>>>> <http://localhost/qgis-mapserv/qgis_mapserv.fcgi?map=%3Cpa
>>>>>>>>>>>>> th_to_your_map%3E/yourmap.qgs?REQUEST=GetCapabilities&SERV
>>>>>>>>>>>>> ICE=WMS&VERSION=1.3> to get the server's capabilites be
>>>>>>>>>>>>> sure to know the possible requests a WMS server can reply
>>>>>>>>>>>>> to, see e.g. [1]
>>>>>>>>>>>>> The client accesses the server and not vice versa.
>>>>>>>>>>>> Ok, I think I understand the philosophy.
>>>>>>>>>>>>> Steps to do:
>>>>>>>>>>>>> 1) Install QGIS server (done)
>>>>>>>>>>>>> 2) Feed QGIS server with a qgis project (*.qgs file)
>>>>>>>>>>>> I saved a QGIS test project with wms capabilites under
>>>>>>>>>>>> /Users/Marcello/Downloads/test/alaska.qgs
>>>>>>>>>>>> The reply of
>>>>>>>>>>>> http://localhost/qgis-mapserv/qgis_mapserv.fcgi?map=/Users/
>>>>>>>>>>>> Marcello/Downloads/test/alaska.qgs&SERVICE=WMS&REQUEST=GetC
>>>>>>>>>>>> apabilities
>>>>>>>>>>>> <http://localhost/qgis-mapserv/qgis_mapserv.fcgi?map=/Users
>>>>>>>>>>>> /Marcello/Downloads/test/alaska.qgs&SERVICE=WMS&REQUEST=Get
>>>>>>>>>>>> Capabilities>
>>>>>>>>>>>> in Safari is:
>>>>>>>>>>>> Configuration file problem : perhaps you left off the .qgs
>>>>>>>>>>>> extension?
>>>>>>>>>>>> Does the project path need special permissions?
>>>>>>>>>>>>> 3) access QGIS server from a WMS client (e.g. QGIS
>>>>>>>>>>>>> desktop) to verify it is running and delivers maps.
>>>>>>>>>>>> Isn't it easier to test this with Safari? In QGIS I tried
>>>>>>>>>>>> to load the alaska layer through "add wms-layer". But i
>>>>>>>>>>>> couldn't connect to my localhost. I don't know what url
>>>>>>>>>>>> exactly is needed. I tried with
>>>>>>>>>>>> http://localhost/Users/Marcello/Downloads/test/alaska.qgs
>>>>>>>>>>>> but its not
>>>>>>>>>>>> working. The message was:
>>>>>>>>>>>> Antwort nicht verstanden. Der wms-Provider sagte:
>>>>>>>>>>>> Eigenschaften-Abfrage gescheitert: Error downloading
>>>>>>>>>>>> http://localhost/Users/Marcello/Downloads/test/alaska.qgs?S
>>>>>>>>>>>> <http://localhost/Users/Marcello/Downloads/test/alaska.qgs?
>>>>>>>>>>>> SERVICE=WMS&REQUEST=GetCapabilities>
>>>>>>>>>>>> - server replied: Not Found
>>>>>>>>>>>>> 4) install and configure QWC, see [2]
>>>>>>>>>>>> Where are this kind of projects normally saved in OSX? I
>>>>>>>>>>>> think the QWC files needs to be saved in the project file
>>>>>>>>>>>> (in my case under /Users/Marcello/Downloads/test)?
>>>>>>>>>>>>> Bernhard
>>>>>>>>>>>>> [1] http://en.wikipedia.org/wiki/Web_Map_Service
>>>>>>>>>>>>> [2]https://github.com/qgis/qgis-web-client
>>>>>>>>>>>>> Am 09.07.2013 13:24, schrieb Marcel Stadelmann:
>>>>>>>>>>>>>> Hi Bernhard,
>>>>>>>>>>>>>> Thank you for answering. On my Mac the Apache server
>>>>>>>>>>>>>> works. The QGIS Server is installed according the
>>>>>>>>>>>>>> Tutorial
>>>>>>>>>>>>>> http://hub.qgis.org/projects/quantum-gis/wiki/QGIS_Server_Tutorial.
>>>>>>>>>>>>>> It
>>>>>>>>>>>>>> also seems to work. When I open the link
>>>>>>>>>>>>>> http://localhost/qgis-mapserv/qgis_mapserv.fcgi? I get
>>>>>>>>>>>>>> the following message from Safari: Please check the value
>>>>>>>>>>>>>> of the REQUEST parameter.
>>>>>>>>>>>>>> Now I try to configure and publish a simple QGIS project.
>>>>>>>>>>>>>> But I don't
>>>>>>>>>>>>>> know where to put the files. I also don't understand how
>>>>>>>>>>>>>> the QGIS Server finds the path to the Web Client, because
>>>>>>>>>>>>>> at the moment I have the qgis-web-client folder in
>>>>>>>>>>>>>> /Users/Marcello/Downloads.
>>>>>>>>>>>>>> Marcel
>>>>>>>>>>>>>> Am 09.07.2013 um 12:52 schrieb Bernhard Str?bl
>>>>>>>>>>>>>>> Hi Marcel,
>>>>>>>>>>>>>>> I am sorry, I do not really understand your question, so
>>>>>>>>>>>>>>> I explain some things, maybe you can reformulate your
>>>>>>>>>>>>>>> question and people with Mac OSX knowledge can help you
>>>>>>>>>>>>>>> then.
>>>>>>>>>>>>>>> qgis-web-client (QWC) is a JavaScript program to be run
>>>>>>>>>>>>>>> in a browser.
>>>>>>>>>>>>>>> To deliver QWC to the browser of your clients you need a
>>>>>>>>>>>>>>> web server (e.g. Apache). You can put QWC whereeever
>>>>>>>>>>>>>>> your web server can access it. QWC needs QGIS Server (a
>>>>>>>>>>>>>>> WMS server), normally you would run QGIS server on the
>>>>>>>>>>>>>>> same machine.
>>>>>>>>>>>>>>> Bernhard
>>>>>>>>>>>>>>> Am 09.07.2013 11:18, schrieb Marcel Stadelmann:
>>>>>>>>>>>>>>>> Hi all,
>>>>>>>>>>>>>>>> I try to install the qgis-web-client on a Mac OSX
>>>>>>>>>>>>>>>> 10.8.4. But I don't understand where exactly I have to
>>>>>>>>>>>>>>>> put it? I think the "/home/web/qgis-web-client" path is
>>>>>>>>>>>>>>>> not for OSX?
>>>>>>>>>>>>>>>> regards,
>>>>>>>>>>>>>>>> Marcel
>>>>>>>>>>>>> __________ Information from ESET Mail Security, version of
>>>>>>>>>>>>> virus signature database 8545 (20130709) __________
>>>>>>>>>>>>> The message was checked by ESET Mail Security.
>>>>>>>>>>>>> http://www.eset.com<http://www.eset.com/>
>>>>>>>>>>>>> _______________________________________________
>>>>>>>>>>>>> Qgis-user at lists.osgeo.org<mailto:Qgis-user at lists.osgeo.org
>>>>>>>>>>> virus signature database 8546 (20130709) __________
>>>>>>>>>>> http://www.eset.com
>>>>>>>>>>> http://www.eset.com
>>>>>>>>>> http://www.eset.com
>>> Qgis-user at lists.osgeo.org <mailto:Qgis-user at lists.osgeo.org>
>>> __________ Information from ESET Mail Security, version of virus
>>> signature database 8551 (20130710) __________
>>> http://www.eset.com
>> http://www.eset.com
> signature database 8552 (20130711) __________
> http://www.eset.com
> http://www.eset.com
__________ Information from ESET Mail Security, version of virus signature database 8552 (20130711) __________
http://www.eset.com
Message: 3
Date: Thu, 11 Jul 2013 17:06:27 +0200
From: Marcel Stadelmann <marcel.stadelmann at gmx.net>
To: "qgis-user at lists.osgeo.org" <qgis-user at lists.osgeo.org>
10.8.4
Message-ID: <81666CF8-52A3-40E2-B08E-E55502000600 at gmx.net>
yeah, with the following url it works and the Alaska map is shown in the browser:
http://localhost/qgis-mapserv/qgis_mapserv.fcgi?map=/Library/WebServer/Documents/alaska.qgs&SERVICE=WMS&VERSION=1.3.0&REQUEST=GetMap&BBOX=-0,0,1000000,8000000&CRS=EPSG:2964&WIDTH=2000&HEIGHT=1194&LAYERS=alaska&STYLES=&FORMAT=image/png&DPI=72&MAP_RESOLUTION=72&FORMAT_OPTIONS=dpi:72
Now I try to install and configure the qgis-web-client.
In the folder /Library/WebServer/Documents/ I did:
sudo git clone https://github.com/qgis/qgis-web-client.git
Then I adjusted the paths in the 3 files (index.html, GlobalOptions.js, GISProjectListing.js). I replaced /home/web/ with /Library/WebServer/Documents/ and (for this I was not sure) /cgi-bin/ with /qgis-mapserv/
Then i tried to load the two examples in qgis-web-client/site/index.html. But the maps are not loading.
I'm not sure what I have to do with the commands in the QGIS Web Client Installation Guide on page 3 (chapter 1 for the terminally lazy). Do I need to do the following commands?
cp apache-conf/qgis-web-client.conf.tmpl apache-conf/qgis-web-client.conf
cd /etc/apache2/sites-available/
ln -s <path to apache-conf/qgis-web-client.conf> .
sudo a2enmod rewrite
sudo a2ensite qgis-web-client.conf
sudo /etc/init.d/apache2 reload
Marcel
Am 11.07.2013 um 11:45 schrieb Bernhard Str?bl <bernhard.stroebl at jena.de>:
> Hi Marcel,
> comment below
>> running, so maybe somebody else can learn from it. I know it's quite
>> basic, but in the beginning it may help. I think in my case, it was a path problem.
>> rights) 2. In QGIS save a project according the QGIS User Manual 1.8
>> Chapter QGIS Server in /Library/WebServer/Documents/ 3. Make sure
>> when reopen the QGIS project from /Library/WebServer/Documents/ it
>> finds still all the layers. (One of my mistakes was, that I moved the
>> project file afterwards into this folder and QGIS couldn't find
>> anymore the alaska.shp file. I thought the layer paths are absolute,
>> but they are not.)
>> wms-layer.
>> r/Documents/alaska.qgs 6. 3 layers appear, add the first one.
>>> Hi Marcel,
>> The url:
>> er/Documents/alaska.qgs&SERVICE=WMS&REQUEST=GetMap>
> Bernahrd
>>> Bernhard
>>>> Hi Andreas,
>>>> BBOX=-15256791.5967269185930490,482471.5356363095343113,15452694.48
>>>> 98276831954718,30602207.0081926248967648&CRS=EPSG:2964&WIDTH=1084&H
>>>> EIGHT=1063&LAYERS=alaska&STYLES=&FORMAT=image/jpeg&DPI=72&MAP_RESOL
>>>> rver/Documents/alaska.qgs&&SERVICE=WMS&VERSION=1.3.0&REQUEST=GetMap
>>>> &BBOX=-15256791.5967269185930490,482471.5356363095343113,15452694.4
>>>> 898276831954718,30602207.0081926248967648&CRS=EPSG:2964&WIDTH=1084&
>>>> HEIGHT=1063&LAYERS=alaska&STYLES=&FORMAT=image/jpeg&DPI=72&MAP_RESO
>>>> LUTION=72&FORMAT_OPTIONS=dpi:72>
>>>> UTION=72&FORMAT_OPTIONS=dpi:72]
>>>> LUTION=72&FORMAT_OPTIONS=dpi:72]>
>>>> but no data are shown.
>>>> Any idea?
>>>> Thank you
>>>> Marcel
>>>>> Hi Marcel,
>>>>> See
>>>>> #Map-parameter
>>>>> is more similar than Windows.
>>>>> Andreas
>>>>>>> Hi Marcel,
>>>>>>> GetCapabilities
>>>>>>> GetMap
>>>>>>> GetLegendGraphic
>>>>>>> GetFeatureInfo
>>>>>>> GetPrint
>>>>>>> that in your new empty test project you specify the same
>>>>>>> projection as in the Alaska sample project. There are
>>>>>>> reprojection options - but for a start it is easier if server
>>>>>>> and client are in the same projection. It will also be faster if
>>>>>>> no reprojection has to be done.
>>>>>> the WMS-Connection is the same with or without the project file
>>>>>>> Andreas
>>>>>>>> Hello Andreas,
>>>>>>>> saved the project file with the new project settings in
>>>>>>>> bServer/Documents/alaska.qgs&SERVICE=WMS&REQUEST=GetCapabilitie
>>>>>>>> s
>>>>>>>> Marcel
>>>>>>>>> Marcel,
>>>>>>>>> Andreas
>>>>>>>>>> I can connect form QGIS Desktop as a WMS-Client to QGIS Server,
>>>>>>>>>> Thanks and regards,
>>>>>>>>>> Marcel
>>>>>>>>>>> Bernhard
>>>>>>>>>>>> don't know
>>>>>>>>>>>> where to save the *.qgs files, so that the QGIS server can
>>>>>>>>>>>> find it.
>>>>>>>>>>>> Thanks and regards,
>>>>>>>>>>>> Marcel
>>>>>>>>>>>>> Hi Bernhard,
>>>>>>>>>>>>>> Hi Marcel,
>>>>>>>>>>>>>> http://localhost/qgis-mapserv/qgis_mapserv.fcgi?map=<path_to_your_map>/yourmap.qgs?REQUEST=GetCapabilities&SERVICE=WMS&VERSION=1.3
>>>>>>>>>>>>>> <http://localhost/qgis-mapserv/qgis_mapserv.fcgi?map=%3Cpath_to_your_map%3E/yourmap.qgs?REQUEST=GetCapabilities&SERVICE=WMS&VERSION=1.3>
>>>>>>>>>>>>>> be sure to know the possible requests a WMS server can
>>>>>>>>>>>>>> reply to, see
>>>>>>>>>>>>>> e.g. [1]
>>>>>>>>>>>>>> Steps to do:
>>>>>>>>>>>>> The reply of
>>>>>>>>>>>>> http://localhost/qgis-mapserv/qgis_mapserv.fcgi?map=/Users/Marcello/Downloads/test/alaska.qgs&SERVICE=WMS&REQUEST=GetCapabilities
>>>>>>>>>>>>> <http://localhost/qgis-mapserv/qgis_mapserv.fcgi?map=/Users/Marcello/Downloads/test/alaska.qgs&SERVICE=WMS&REQUEST=GetCapabilities>
>>>>>>>>>>>>> in Safari is:
>>>>>>>>>>>>> extension?
>>>>>>>>>>>>>> 3) access QGIS server from a WMS client (e.g. QGIS desktop)
>>>>>>>>>>>>>> to verify
>>>>>>>>>>>>> Isn't it easier to test this with Safari? In QGIS I tried to
>>>>>>>>>>>>> load the
>>>>>>>>>>>>> alaska layer through "add wms-layer". But i couldn't connect
>>>>>>>>>>>>> to my
>>>>>>>>>>>>> localhost. I don't know what url exactly is needed. I tried with
>>>>>>>>>>>>> but its not
>>>>>>>>>>>>> http://localhost/Users/Marcello/Downloads/test/alaska.qgs?SERVICE=WMS&REQUEST=GetCapabilities
>>>>>>>>>>>>> <http://localhost/Users/Marcello/Downloads/test/alaska.qgs?SERVICE=WMS&REQUEST=GetCapabilities>
>>>>>>>>>>>>> think the QWC
>>>>>>>>>>>>> files needs to be saved in the project file (in my case under
>>>>>>>>>>>>>> Bernhard
>>>>>>>>>>>>>>> Hi Bernhard,
>>>>>>>>>>>>>>> works. The QGIS
>>>>>>>>>>>>>>> Server is installed according the Tutorial
>>>>>>>>>>>>>>> It
>>>>>>>>>>>>>>> http://localhost/qgis-mapserv/qgis_mapserv.fcgi? I get the
>>>>>>>>>>>>>>> following
>>>>>>>>>>>>>>> message from Safari: Please check the value of the REQUEST
>>>>>>>>>>>>>>> parameter.
>>>>>>>>>>>>>>> But I don't
>>>>>>>>>>>>>>> the QGIS Server
>>>>>>>>>>>>>>> finds the path to the Web Client, because at the moment I
>>>>>>>>>>>>>>> have the
>>>>>>>>>>>>>>> qgis-web-client folder in /Users/Marcello/Downloads.
>>>>>>>>>>>>>>> Marcel
>>>>>>>>>>>>>>>> Hi Marcel,
>>>>>>>>>>>>>>>> I explain
>>>>>>>>>>>>>>>> some things, maybe you can reformulate your question and
>>>>>>>>>>>>>>>> people with
>>>>>>>>>>>>>>>> Mac OSX knowledge can help you then.
>>>>>>>>>>>>>>>> in a browser.
>>>>>>>>>>>>>>>> web server
>>>>>>>>>>>>>>>> (e.g. Apache). You can put QWC whereeever your web server
>>>>>>>>>>>>>>>> can access
>>>>>>>>>>>>>>>> it. QWC needs QGIS Server (a WMS server), normally you
>>>>>>>>>>>>>>>> would run QGIS
>>>>>>>>>>>>>>>> server on the same machine.
>>>>>>>>>>>>>>>> Bernhard
>>>>>>>>>>>>>>>>> Hi all,
>>>>>>>>>>>>>>>>> 10.8.4. But I don't
>>>>>>>>>>>>>>>>> understand where exactly I have to put it? I think the
>>>>>>>>>>>>>>>>> "/home/web/qgis-web-client" path is not for OSX?
>>>>>>>>>>>>>>>>> regards,
>>>>>>>>>>>>>>>>> Marcel
>>>>>>>>>>>>>> virus
>>>>>>>>>>>>>> Qgis-user at lists.osgeo.org<mailto:Qgis-user at lists.osgeo.org>
>>>>>>>>>>>> http://www.eset.com
>>>>>>>>>>>> http://www.eset.com
>>>>>>>>>>> http://www.eset.com
>>>> http://www.eset.com
>>> http://www.eset.com
>> http://www.eset.com
>> http://www.eset.com
> http://www.eset.com
End of Qgis-user Digest, Vol 89, Issue 61
