[Qgis-user] Some updated info for compiling qgis under ubuntu
Agustin Lobo
alobolistas at gmail.com
Fri Jul 12 01:44:36 PDT 2013
Because of the broken dependencies of the nightly-build, just compiled
qgis master under linuxmint 15, which is based on ubuntu raring.
I followed
http://www.qgis.org/api/INSTALL.html#toc3
with the following changes/additions/notes:
1 I installed dependencies for precise (no newer versions recorded in
that page...)
2. sudo apt-get install cmake-curses-gui
3. ccmake ..
Changed:
CMAKE_INSTALL_PREFIX=${HOME}/apps
QMAKE_EXECUTABLE=/usr/bin/qmake-qt4
/usr/lib/x86_64-linux-gnu/libpython2.7.so
4. After make and make install, I try
$HOME/apps/bin/qgis
/home/alobo/apps/bin/qgis: error while loading shared libraries:
libqgis_core.so.1.9.0: cannot open shared object file: No such file or
directory
but libqgis_core.so.1.9.0 has just been installed under ${HOME}/apps/lib, thus
export LD_LIBRARY_PATH=/home/alobo/apps/lib
and qgis works (somehow, though: it's a dev version)
Agus
