[Qgis-user] Some updated info for compiling qgis under ubuntu
Agustin Lobo
alobolistas at gmail.com
Fri Jul 12 10:20:38 PDT 2013
There is an error in my previous message:
3. ccmake ..
Changed:
CMAKE_INSTALL_PREFIX=${HOME}/apps
QMAKE_EXECUTABLE=/usr/bin/qmake-qt4
PYTHON_LIBRARY=/usr/lib/x86_64-linux-gnu/libpython2.7.so
Agus
On Fri, Jul 12, 2013 at 10:44 AM, Agustin Lobo <alobolistas at gmail.com> wrote:
> Because of the broken dependencies of the nightly-build, just compiled
> qgis master under linuxmint 15, which is based on ubuntu raring.
> I followed
> http://www.qgis.org/api/INSTALL.html#toc3
> with the following changes/additions/notes:
> 1 I installed dependencies for precise (no newer versions recorded in
> that page...)
> 2. sudo apt-get install cmake-curses-gui
> 3. ccmake ..
> Changed:
> 4. After make and make install, I try
> $HOME/apps/bin/qgis
> /home/alobo/apps/bin/qgis: error while loading shared libraries:
> libqgis_core.so.1.9.0: cannot open shared object file: No such file or
> directory
> but libqgis_core.so.1.9.0 has just been installed under ${HOME}/apps/lib, thus
> export LD_LIBRARY_PATH=/home/alobo/apps/lib
> and qgis works (somehow, though: it's a dev version)
> Agus
