[Qgis-user] line to polygon problem
Carlos Cerdán
sig.upagu at gmail.com
Mon Jul 15 08:41:36 PDT 2013
Hi Tudor
Something is wrong with single_line_to_polygon layer, it's not editable.
I got the polygon from several_lines_to_polygon layer:
1. Turn this layer editable
2. Select all the lines
3. Edit --> Combine selected spatial objects
4. Save and turn off edition
5. Use Vectorial --> Geometry tools --> Lines to poligons. Use the combined
several_lines_to_polygon layer.
6. You have the polygon that you are looking for.
Good luck
Carlos Cerdán
2013/7/14 Tudor Barascu <tudorbarascu at yahoo.com>
> Hi everyone,
> It seems I have found a bug as I tried to create polygons from lines in
> Qgis 1.8 and 1.9 master and it doesn't work.
> I have used the same data on another computer and the problem persists.
> The tool works for other data sets but not on this one. I first thought it
> was a data set problem but I checked for geometry & topology errors and I
> couldn't find anything. Moreover, It worked in ArcGIS. I have attached the
> lines shapefile data in a small zip file.
> Can anyone else replicate it and maybe shade a light on it?
> All the best,
> Tudor Barascu
> https://www.dropbox.com/s/aylwcrlgfwfqm9m/Qgis%20problem.zip
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20130715/2ba6a0de/attachment.html>
