[Qgis-user] line to polygon problem
    Gerardo Jimenez
    gejst5 at hotmail.com
    Mon Jul 15 18:04:55 PDT 2013
The method described by Carlos works smoothly
Gerardo Jiménez Delgado
Instituto de Investigaciones Antropológicas
Universidad Nacional Autónoma de México
Ciudad Universitaria s/n
Coyoacan 04510
Mexico City
Mexico
56 22 95 16
Date: Mon, 15 Jul 2013 10:41:36 -0500
To: tudorbarascu at yahoo.com
CC: qgis-user at lists.osgeo.org
Subject: Re: [Qgis-user] line to polygon problem
Hi Tudor
Something is wrong with single_line_to_polygon layer, it's not editable.
I got the polygon from several_lines_to_polygon layer:
1. Turn this layer editable
2. Select all the lines
3. Edit --> Combine selected spatial objects
4. Save and turn off edition
5. Use Vectorial --> Geometry tools --> Lines to poligons. Use the combined several_lines_to_polygon layer.
6. You have the polygon that you are looking for.
Good luck
Carlos Cerdán
2013/7/14 Tudor Barascu <tudorbarascu at yahoo.com>
Hi everyone,
It seems I have found a bug as I tried to create polygons  from lines in Qgis 1.8 and 1.9 master and it doesn't work.
I have used the same data on another computer and the problem persists.
The tool works for other data sets but not on this one. I first thought it was a data set problem but I checked for geometry &
 topology errors and I couldn't find anything. Moreover, It worked in ArcGIS. I have attached the lines shapefile data in a small zip file.
Can anyone else replicate it and maybe shade a light on it?
All the best,Tudor Barascu
https://www.dropbox.com/s/aylwcrlgfwfqm9m/Qgis%20problem.zip
Qgis-user mailing list
Qgis-user at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/qgis-user
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20130715/8279d934/attachment.html>
