[Qgis-user] Rasterize (vector to raster) no longer exists
    William Kyngesburye
    woklist at kyngchaos.com
    Wed Jul 17 16:54:57 PDT 2013
If it's GDAL 1.10 causing the problem, did anyone say anything on the list or in a bug report.  I just blindly rebuilt my OS X QGIS to use GDAL 1.10, it would have been nice to know I should not have.
Is there a simple fix for this that I could add to my QGIS 1.8 build?
If not, Thiago, then reinstall QGIS 1.8-1, this will use the old GDAL 1.9 framework which should still be installed, though the GDAL path in GdalTools config will still point to the latest GDAL 1.10.  For simplicity, reinstall GDAL 1.9, that will reset the default GDAL version, yet still leave both 1.9 and 1.10 installed.  You should probably then reinstall the previous GRASS 6.4.2-? (I forget which build version).  But, I haven't updated my archive in a while so these old versions will be difficult to find if you don't have your own backup of them.
... for all that hassle, I hope that the GdalTools can be easily fixed to avoid all the downgrading.
On Jul 17, 2013, at 5:45 PM, Etienne Tourigny wrote:
> I am pretty sure it is due to gdal-1.10. The GdalTools plugin has to fixed to support gdal-1.10.  Can you try to downgrade to gdal-1.9?
> Cheers
> Etienne
> On Wed, Jul 17, 2013 at 4:46 PM, Thiago V. dos Santos <thi_veloso at yahoo.com.br> wrote:
> Dear Etienne, Wernner and Giovanni,
> Thanks for the feedback. I examined each of your suggestion and I'm still not sure on what is causing the lack of some options. Everything is enabled, and still the only option I have under raster -> conversion are:
> - Translate (convert format)
> - RGB to PCT
> -  PCT to RGB
> GDAL Path is configured under gdaltools settings as follows:
> /Library/Frameworks/GDAL.framework/Programs:/usr/bin
> (just like recommended by the maintaner of the packages for Mac)
> Any clue?
> Regards,
> PhD student
> Land and Atmospheric Science
> University of Minnesota
> http://www.laas.umn.edu/CurrentStudents/MeettheStudents/ThiagodosSantos/index.htm
> Phone: (612) 323 9898
> From: Etienne Tourigny <etourigny.dev at gmail.com>
> To: Thiago V. dos Santos <thi_veloso at yahoo.com.br>
> Cc: "qgis-user at lists.osgeo.org" <qgis-user at lists.osgeo.org>
> Sent: Wednesday, July 17, 2013 9:33 AM
> Subject: Re: [Qgis-user] Rasterize (vector to raster) no longer exists
> Hi Thiago!
> Is GdalTools plugin available and enabled? Do you see other tools in the Raster menu?
> cheers mate!
> Etienne
> On Wed, Jul 17, 2013 at 10:59 AM, Thiago V. dos Santos <thi_veloso at yahoo.com.br> wrote:
> No one?
> Yesterday I installed the lates QGIS on my Windows laptop and there were all the menus I was used to (including "rasterize", which I was looking for). Every little option was available, unlike Mac/Linux version.
> Does anybody know why some options are supressed on Mac/Linux version of QGIS?
> Regards,
> PhD student
> From: Thiago V. dos Santos <thi_veloso at yahoo.com.br>
> To: "qgis-user at lists.osgeo.org" <qgis-user at lists.osgeo.org>
> Sent: Friday, July 12, 2013 3:54 PM
> Subject: [Qgis-user] Rasterize (vector to raster) no longer exists
> Hi everybody,
> First post in this list, so please excuse any mistake.
> I'm a GIS user on Mac (Mountain Lion) and I have been using using latest gdal (1.10) and Qgis (1.8.0-2) provided by Kyng Chaos.
> I need to convert a vector to a raster, which previously could be done with "rasterize" under the "Raster -> conversion" menu (once the vector was loaded). In  the past I used this option very often, but I couldn't find it today.
> Am I missing something or was this option replaced/removed from Qgis?
> Greetings,
> PhD student
> Qgis-user mailing list
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
First Pogril: Why is life like sticking your head in a bucket filled with hyena offal?
Second Pogril: I don't know.  Why IS life like sticking your head in a bucket filled with hyena offal?
First Pogril: I don't know either.  Wretched, isn't it?
-HitchHiker's Guide to the Galaxy
