[Qgis-user] Remove all rings with a polygon
    Saber Razmjooei
    saber.razmjooei at lutraconsulting.co.uk
    Fri Jul 19 13:11:34 PDT 2013
Have you tried
v.clean
http://grass.osgeo.org/grass64/manuals/v.clean.html
Cheers
Saber
[mailto:qgis-user-bounces at lists.osgeo.org] On Behalf Of Matt Travis
Sent: 19 July 2013 19:09
To: qgis-user at lists.osgeo.org
Subject: [Qgis-user] Remove all rings with a polygon
I have a uk postcode layer that in have clipped to the boundary of my
authority and have then used the dissolve function to aggregate these into
postcode sectors. When I do this though there are hundreds of little rings
left over by the vertical postcodes (blocks of flats I presume). I wish to
remove these but don't know how to delete rings apart from clicking on each
one.
Is there a function someehwere i could use (grass?) or do need to write
python script?
Thanks
Matt
This email and any files transmitted with it are confidential and intended solely for the use of the individual or entity to whom they are addressed.
If you have received this email in error please notify the system manager. This message contains confidential information and is intended only for the
individual named. If you are not the named addressee you should not disseminate, distribute or copy this e-mail. Please notify the sender immediately
by e-mail if you have received this e-mail by mistake and delete this e-mail from your system. If you are not the intended recipient you are notified
that disclosing, copying, distributing or taking any action in reliance on the contents of this information is strictly prohibited.
Whilst reasonable care has been taken to avoid virus transmission, no responsibility for viruses is taken and it is your responsibility to carry out
such checks as you feel appropriate.
Saber Razmjooei and Peter Wells trading as Lutra Consulting.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20130719/89289bc5/attachment.html>
