[Qgis-user] Remove all rings with a polygon
Matt Travis matt.travis1 at gmail.com
Fri Jul 19 13:29:11 PDT 2013
Remove small areas function should work.
Thanks
Matt
On 19 Jul 2013 21:11, "Saber Razmjooei" <
saber.razmjooei at lutraconsulting.co.uk> wrote:
> Have you tried ****
> v.clean****
> http://grass.osgeo.org/grass64/manuals/v.clean.html****
> Cheers****
> Saber****
> *From:* qgis-user-bounces at lists.osgeo.org [mailto:
> qgis-user-bounces at lists.osgeo.org] *On Behalf Of *Matt Travis
> *Sent:* 19 July 2013 19:09
> *To:* qgis-user at lists.osgeo.org
> *Subject:* [Qgis-user] Remove all rings with a polygon****
> I have a uk postcode layer that in have clipped to the boundary of my
> authority and have then used the dissolve function to aggregate these into
> postcode sectors. When I do this though there are hundreds of little rings
> left over by the vertical postcodes (blocks of flats I presume). I wish to
> remove these but don't know how to delete rings apart from clicking on each
> one. ****
> Is there a function someehwere i could use (grass?) or do need to write
> python script?
> Thanks****
> Matt****
> This email and any files transmitted with it are confidential and intended
> solely for the use of the individual or entity to whom they are addressed.
> If you have received this email in error please notify the system manager.
> This message contains confidential information and is intended only for the
> individual named. If you are not the named addressee you should not
> disseminate, distribute or copy this e-mail. Please notify the sender
> immediately by e-mail if you have received this e-mail by mistake and
> delete this e-mail from your system. If you are not the intended recipient
> you are notified that disclosing, copying, distributing or taking any
> action in reliance on the contents of this information is strictly
> prohibited.
> Whilst reasonable care has been taken to avoid virus transmission, no
> responsibility for viruses is taken and it is your responsibility to carry
> out such checks as you feel appropriate.
> Saber Razmjooei and Peter Wells trading as Lutra Consulting.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20130719/692b6c60/attachment.html>
