[Qgis-user] Map extent
Andreas Neumann a.neumann at carto.net
Mon Jun 3 21:15:13 PDT 2013
Hi Arif,
If you expect an answer from this list - please provide the necessary
information. With the information you provide, noone is able to help you.
Provide a URL to your server so we can have a look at it and better
describe the expected behaviour and what fails.
Also provide version information and the browsers you tested with.
and please: do not hijack email threads from other people. If you have a
new problem then use a new thread and do not reply to existing ones.
Regards,
Andreas
Am 03.06.2013 21:07, schrieb arif arham:
> Andreas,
> I created a map in QGis. However, when I opened it in qgis web client, the
> map extent was not display correctly/similarly.
> Is there any setting in GlobalSetting.js or its about CRS?
> Arif Arham <http://khazanaharham.wordpress.com/>
>> .sent from my phone.
>> On May 27, 2013 6:15 PM, "Andreas Neumann" <a.neumann at carto.net> wrote:
>>> Hi Katrin,
>>> See menu "Vector" --> "Research Tools" --> "Vector grid".
>>> This should work for rasters with equal sizes. If every raster set has a
>>> different size and extent you probably would have to write a python script
>>> to step through all open raster layers, read out the extent values and
>>> create the grids by script.
>>> Hope this helps,
>>> Andreas
>>> On Mon, 27 May 2013 10:59:26 +0100, katrin eggert wrote:
>>>> Dear all,
>>>> I'm doing some photo-interpretation and, in order to organize my work,
>>>> I would like to create a grid and customize it (my idea is to organize
>>>> my tasks by grid-cell). Is  it possible to create and customize a
>>>> grid cell to be overlayed with my satellite images (and vecot layers)?
>>>> Thanks
>>>> Kat
>>> Andreas Neumann
>>> Böschacherstrasse 10A
>>> 8624 Grüt (Gossau ZH)
>>> Switzerland
>>> ______________________________**_________________
>>> Qgis-user mailing list
>>> Qgis-user at lists.osgeo.org
>>> http://lists.osgeo.org/**mailman/listinfo/qgis-user<http://lists.osgeo.org/mailman/listinfo/qgis-user>
