[Qgis-user] Map extent
arif arham
arhamilis at gmail.com
Sat Jun 8 21:38:56 PDT 2013
I work on a localserver using Ubuntu 13.04 and QGIS 1.8
I used the default configuration of the current web-qgis-client-master.
Sorry for the hijack. Its my bad.
.sent from my phone.
On Jun 4, 2013 11:15 AM, "Andreas Neumann" <a.neumann at carto.net> wrote:
> Hi Arif,
> If you expect an answer from this list - please provide the necessary
> information. With the information you provide, noone is able to help you.
> Provide a URL to your server so we can have a look at it and better
> describe the expected behaviour and what fails.
> Also provide version information and the browsers you tested with.
> and please: do not hijack email threads from other people. If you have a
> new problem then use a new thread and do not reply to existing ones.
> Regards,
> Andreas
> Am 03.06.2013 21:07, schrieb arif arham:
> > Andreas,
> > I created a map in QGis. However, when I opened it in qgis web client,
the
> > map extent was not display correctly/similarly.
> > Is there any setting in GlobalSetting.js or its about CRS?
> > Arif Arham <http://khazanaharham.wordpress.com/>
> > On Mon, Jun 3, 2013 at 4:38 PM, arif arham <arhamilis at gmail.com> wrote:
the
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20130609/cabf61cf/attachment.html>
