[Qgis-user] Error Delete Duplicate Geometries in QGIS v1.9
Blumentrath, Stefan
Stefan.Blumentrath at nina.no
Wed Jun 5 12:33:39 PDT 2013
Hi Samuel
You could consider using v.clean from GRASS through Sextante.
We had a discussion about it a while ago (http://osgeo-org.1560.x6.nabble.com/Running-v-clean-on-a-QGIS-vector-layer-Polygon-through-Sextante-tt5050418.html). It should do what you want (if I understood you correctly).
Cheers
Stefan
From: qgis-user-bounces at lists.osgeo.org [mailto:qgis-user-bounces at lists.osgeo.org] On Behalf Of samuelmesa at gmail.com
Sent: 5. juni 2013 21:22
Cc: qgis-user
Subject: Re: [Qgis-user] Error Delete Duplicate Geometries in QGIS v1.9
Giovanni, the Tool is in Sextante Toolbox -> QGIS geoalgorithms -> Vector general tools -> Delete duplicate geometries (attached screenshot). This tool does not work in version 1.9 Master, but if it works properly in version 1.8.
Another question, is it possible to install the library LWGEOM in OSGeo4W?
Thank you Giovanni,
Samuel Mesa.
2013/6/5 Giovanni Manghi <giovanni.manghi at faunalia.pt<mailto:giovanni.manghi at faunalia.pt>>
> Hi list, I'm building a model Sextante and I have an error with the Delete
> Duplicate Geometries algorithm in QGIS v1.9 (OSGeo4W). In the version 1.8, I
> get the correct results for the example in the shapefile attached, I must get
> 21 features and should not be 22 features.
what tool are you talking about?
> Is possible to include Eliminate tool Sliver polygons in Sextant? or can be
> installed LWGEOM in OSGeo4W?, This could help me in the duplicate
> features produced
> by overlay tools.
http://hub.qgis.org/issues/7696
cheers!
Qgis-user mailing list
Qgis-user at lists.osgeo.org<mailto:Qgis-user at lists.osgeo.org>
http://lists.osgeo.org/mailman/listinfo/qgis-user
/ v \
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20130605/95949cee/attachment.html>
