[Qgis-user] QGIS with SAGA in macos
Agustin Diez-Castillo gvsig.mac at gmail.com
Tue Jun 11 08:32:51 PDT 2013
Hi all,
Some time ago, there were discussion on this list about running saga in
qgis for mac. As of today, the good news are that in master 499db4e it
seems that the saga commands run [1], however results are not as expected.
If I leave the raster as a temporary file something (ERROR 1: Writing
through VRTSourcedRasterBand is not supported) goes wrong, when I try to
the same but saving the result a python error [2] doesn't allow me to
create the desired tif.
Some saga command producing vector results run OK.
This time I was on macos 10.8.4.
Best
Agustin
[1]
SAGA execution console output
05:05:07 PM: Debug: Adding duplicate image handler for 'PNG file'
05:05:07 PM: Debug: Adding duplicate image handler for 'JPEG file'
05:05:07 PM: Debug: Adding duplicate image handler for 'TIFF file'
05:05:07 PM: Debug: Adding duplicate image handler for 'GIF file'
05:05:07 PM: Debug: Adding duplicate image handler for 'PNM file'
05:05:07 PM: Debug: Adding duplicate image handler for 'PCX file'
05:05:07 PM: Debug: Adding duplicate image handler for 'IFF file'
05:05:07 PM: Debug: Adding duplicate image handler for 'Windows icon file'
05:05:07 PM: Debug: Adding duplicate image handler for 'Windows cursor file'
05:05:07 PM: Debug: Adding duplicate image handler for 'Windows animated
cursor file'
05:05:07 PM: Debug: Adding duplicate image handler for 'TGA file'
05:05:07 PM: Debug: Adding duplicate image handler for 'XPM file'
_____________________________________________
library path: /Applications/SAGA.app/lib/saga/libio_gdal.dylib
library name: Import/Export - GDAL/OGR
module name : GDAL: Import Raster
author : O.Conrad (c) 2007 (A.Ringeler)
Parameters
Grids: No objects
Files:
"/var/folders/sm/1djysrdj1clbzvn35gv8vqq40000gn/T/sextante/sagaslopeaspectcurvature1ede263e70484902b4097120c94fbf1d.tif"
Transformation: no
Interpolation: B-Spline Interpolation
loading:
Driver:
/var/folders/sm/1djysrdj1clbzvn35gv8vqq40000gn/T/sextante/sagaslopeaspectcurvature1ede263e70484902b4097120c94fbf1d.tif/
Cells: x 2000, y 2000
Bands: 1
Transformation x' = 700000.000000 + x * 25.000000 + y * 0.000000
Transformation y' = 4325000.000000 + x * 0.000000 + y * -25.000000
loading band [1/1]
Save grid:
/var/folders/sm/1djysrdj1clbzvn35gv8vqq40000gn/T/sextante/33fe826d05a04ddebf423a5f4adb31ef/sagas.sgrd...
ready
okay
05:05:09 PM: Debug: Adding duplicate image handler for 'PNG file'
05:05:09 PM: Debug: Adding duplicate image handler for 'JPEG file'
05:05:09 PM: Debug: Adding duplicate image handler for 'TIFF file'
05:05:09 PM: Debug: Adding duplicate image handler for 'GIF file'
05:05:09 PM: Debug: Adding duplicate image handler for 'PNM file'
05:05:09 PM: Debug: Adding duplicate image handler for 'PCX file'
05:05:09 PM: Debug: Adding duplicate image handler for 'IFF file'
05:05:09 PM: Debug: Adding duplicate image handler for 'Windows icon file'
05:05:09 PM: Debug: Adding duplicate image handler for 'Windows cursor file'
05:05:09 PM: Debug: Adding duplicate image handler for 'Windows animated
cursor file'
05:05:09 PM: Debug: Adding duplicate image handler for 'TGA file'
05:05:09 PM: Debug: Adding duplicate image handler for 'XPM file'
library path: /Applications/SAGA.app/lib/saga/libta_morphometry.dylib
library name: Terrain Analysis - Morphometry
module name : Slope, Aspect, Curvature
author : O.Conrad (c) 2001
Load grid:
ready
okay
Parameters
Grid system: 25; 2000x 2000y; 700012.5x 4275012.5y
Elevation: sagas
Slope: Slope
Aspect: Aspect
Curvature: Curvature
Plan Curvature: Plan Curvature
Profile Curvature: Profile Curvature
Method: Fit 2.Degree Polynom (Zevenbergen & Thorne 1987)
Save grid:
/var/folders/sm/1djysrdj1clbzvn35gv8vqq40000gn/T/sextante/sagaslopeaspectcurvature62a54bf65e34409caf443172524059bb.tif.sgrd...
ready
okay
Save grid:
/var/folders/sm/1djysrdj1clbzvn35gv8vqq40000gn/T/sextante/sagaslopeaspectcurvature2bd964a53d7e47459c3b168c73a976b7.tif.sgrd...
ready
okay
Save grid:
/var/folders/sm/1djysrdj1clbzvn35gv8vqq40000gn/T/sextante/sagaslopeaspectcurvature94dc20ffc26546d4838ac820666d427c.tif.sgrd...
ready
okay
Save grid:
/var/folders/sm/1djysrdj1clbzvn35gv8vqq40000gn/T/sextante/sagaslopeaspectcurvatured252caaa30454787a27a77dc5b9acd64.tif.sgrd...
ready
okay
Save grid:
/var/folders/sm/1djysrdj1clbzvn35gv8vqq40000gn/T/sextante/sagaslopeaspectcurvature29c5f1f974c44284b8fecc9e7c09e85d.tif.sgrd...
ready
okay
05:05:18 PM: Debug: Adding duplicate image handler for 'PNG file'
05:05:18 PM: Debug: Adding duplicate image handler for 'JPEG file'
05:05:18 PM: Debug: Adding duplicate image handler for 'TIFF file'
05:05:18 PM: Debug: Adding duplicate image handler for 'GIF file'
05:05:18 PM: Debug: Adding duplicate image handler for 'PNM file'
05:05:18 PM: Debug: Adding duplicate image handler for 'PCX file'
05:05:18 PM: Debug: Adding duplicate image handler for 'IFF file'
05:05:18 PM: Debug: Adding duplicate image handler for 'Windows icon file'
05:05:18 PM: Debug: Adding duplicate image handler for 'Windows cursor file'
05:05:18 PM: Debug: Adding duplicate image handler for 'Windows animated
cursor file'
05:05:18 PM: Debug: Adding duplicate image handler for 'TGA file'
05:05:18 PM: Debug: Adding duplicate image handler for 'XPM file'
ERROR 1: Writing through VRTSourcedRasterBand is not supported.
error: Writing dataset failed.
error: Dataset creation failed: Writing through VRTSourcedRasterBand is not
supported.
error: executing module [GDAL: Export Raster]
module name : GDAL: Export Raster
Load grid:
ready
okay
Parameters
Grid(s): 1 object
(sagaslopeaspectcurvature62a54bf65e34409caf443172524059bb.tif)
File:
Format: Virtual Raster
Data Type: match input data
Creation Options:
Band 1
05:05:19 PM: Debug: Adding duplicate image handler for 'JPEG file'
05:05:19 PM: Debug: Adding duplicate image handler for 'TIFF file'
05:05:19 PM: Debug: Adding duplicate image handler for 'GIF file'
05:05:19 PM: Debug: Adding duplicate image handler for 'PNM file'
05:05:19 PM: Debug: Adding duplicate image handler for 'PCX file'
05:05:19 PM: Debug: Adding duplicate image handler for 'IFF file'
05:05:19 PM: Debug: Adding duplicate image handler for 'Windows icon file'
05:05:19 PM: Debug: Adding duplicate image handler for 'Windows cursor file'
05:05:19 PM: Debug: Adding duplicate image handler for 'Windows animated
cursor file'
05:05:19 PM: Debug: Adding duplicate image handler for 'TGA file'
05:05:19 PM: Debug: Adding duplicate image handler for 'XPM file'
supported.
Load grid:
ready
okay
Parameters
Grid(s): 1 object
(sagaslopeaspectcurvature2bd964a53d7e47459c3b168c73a976b7.tif)
File:
Creation Options:
Band 1
05:05:21 PM: Debug: Adding duplicate image handler for 'JPEG file'
05:05:21 PM: Debug: Adding duplicate image handler for 'TIFF file'
05:05:21 PM: Debug: Adding duplicate image handler for 'GIF file'
05:05:21 PM: Debug: Adding duplicate image handler for 'PNM file'
05:05:21 PM: Debug: Adding duplicate image handler for 'PCX file'
05:05:21 PM: Debug: Adding duplicate image handler for 'IFF file'
05:05:21 PM: Debug: Adding duplicate image handler for 'Windows icon file'
05:05:21 PM: Debug: Adding duplicate image handler for 'Windows cursor file'
05:05:21 PM: Debug: Adding duplicate image handler for 'Windows animated
cursor file'
05:05:21 PM: Debug: Adding duplicate image handler for 'TGA file'
05:05:21 PM: Debug: Adding duplicate image handler for 'XPM file'
supported.
Load grid:
ready
okay
Parameters
Grid(s): 1 object
(sagaslopeaspectcurvature94dc20ffc26546d4838ac820666d427c.tif)
File:
Creation Options:
Band 1
05:05:22 PM: Debug: Adding duplicate image handler for 'JPEG file'
05:05:22 PM: Debug: Adding duplicate image handler for 'TIFF file'
05:05:22 PM: Debug: Adding duplicate image handler for 'GIF file'
05:05:22 PM: Debug: Adding duplicate image handler for 'PNM file'
05:05:22 PM: Debug: Adding duplicate image handler for 'PCX file'
05:05:22 PM: Debug: Adding duplicate image handler for 'IFF file'
05:05:22 PM: Debug: Adding duplicate image handler for 'Windows icon file'
05:05:22 PM: Debug: Adding duplicate image handler for 'Windows cursor file'
05:05:22 PM: Debug: Adding duplicate image handler for 'Windows animated
cursor file'
05:05:22 PM: Debug: Adding duplicate image handler for 'TGA file'
05:05:22 PM: Debug: Adding duplicate image handler for 'XPM file'
supported.
Load grid:
ready
okay
Parameters
Grid(s): 1 object
(sagaslopeaspectcurvatured252caaa30454787a27a77dc5b9acd64.tif)
File:
Creation Options:
Band 1
05:05:24 PM: Debug: Adding duplicate image handler for 'JPEG file'
05:05:24 PM: Debug: Adding duplicate image handler for 'TIFF file'
05:05:24 PM: Debug: Adding duplicate image handler for 'GIF file'
05:05:24 PM: Debug: Adding duplicate image handler for 'PNM file'
05:05:24 PM: Debug: Adding duplicate image handler for 'PCX file'
05:05:24 PM: Debug: Adding duplicate image handler for 'IFF file'
05:05:24 PM: Debug: Adding duplicate image handler for 'Windows icon file'
05:05:24 PM: Debug: Adding duplicate image handler for 'Windows cursor file'
05:05:24 PM: Debug: Adding duplicate image handler for 'Windows animated
cursor file'
05:05:24 PM: Debug: Adding duplicate image handler for 'TGA file'
05:05:24 PM: Debug: Adding duplicate image handler for 'XPM file'
supported.
Load grid:
ready
okay
Parameters
Grid(s): 1 object
(sagaslopeaspectcurvature29c5f1f974c44284b8fecc9e7c09e85d.tif)
File:
Creation Options:
Band 1
[2]
An error has occured while executing Python code:
  File
"/Applications/QGIS_2.0-dev.app/Contents/MacOS/../Resources/python/plugins/sextante/gui/OutputSelectionPanel.py",
line 92, in saveToFile
    filename= unicode(files.first())
AttributeError: 'list' object has no attribute 'first'
Python version:
2.7.2 (default, Oct 11 2012, 20:14:37)
[GCC 4.2.1 Compatible Apple Clang 4.0 (tags/Apple/clang-418.0.60)]
QGIS version:
1.9.0-Master Master, 499db4e
Python path:
['/Applications/QGIS_2.0-dev.app/Contents/MacOS/../Resources/python/plugins/sextante',
'/Applications/QGIS_2.0-dev.app/Contents/MacOS/../Resources/python',
'/Users/adiez/.qgis2/python', '/Users/adiez/.qgis2/python/plugins',
'/Applications/QGIS_2.0-dev.app/Contents/MacOS/../Resources/python/plugins',
'/Library/Frameworks/SQLite3.framework/Versions/B/Python/2.7',
'/Library/Python/2.7/site-packages/numpy-override',
'/Library/Frameworks/MapServer.framework/Versions/6.0/Python/2.7',
'/Library/Frameworks/GDAL.framework/Versions/1.10/Python/2.7/site-packages',
'/Library/Frameworks/cairo.framework/Versions/1/Python/2.7',
'/usr/local/lib/wxPython-2.9.4.0/lib/python2.7/site-packages',
'/usr/local/lib/wxPython-2.9.4.0/lib/python2.7/site-packages/wx-2.9.4-osx_cocoa',
'/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python27.zip',
'/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7',
'/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/plat-darwin',
'/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/plat-mac',
'/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/plat-mac/lib-scriptpackages',
'/System/Library/Frameworks/Python.framework/Versions/2.7/Extras/lib/python',
'/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/lib-tk',
'/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/lib-old',
'/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/lib-dynload',
'/System/Library/Frameworks/Python.framework/Versions/2.7/Extras/lib/python/PyObjC',
'/Library/Python/2.7/site-packages',
'/Library/Python/2.7/site-packages/PIL',
'/usr/local/lib/wxPython-2.9.4.0/lib/python2.7',
'/Applications/QGIS_2.0-dev.app/Contents/Resources/python/plugins/fTools/tools']
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20130611/5d30b896/attachment.html>
