[Qgis-user] qgis 2.0 does not respect labels' scale-based visibility option when opening existing 1.9 projects
Andreas Neumann
a.neumann at carto.net
Wed Jun 12 00:57:37 PDT 2013
I can confirm this issue. The min/max scales are set but disabled because the checkbox is turned off.
It is a migration issue of old projects.
Did you submit a bug?
Andreas
Giovanni Manghi <giovanni.manghi at faunalia.pt> schrieb:
>Hi Duarte,
>> Can someone confirm? What I'm seeing is QGIS not turning on this
>option, but still maintaining the scale range values. It should open
>the project and keep the scale-based visibility option turned on
>it seems to work fine with new projects, maybe there is something
>wrong with projects created before the labeling overhaul of the last
>weeks. Can you confirm?
>cheers
>-- Giovanni --
>_______________________________________________
>Qgis-user mailing list
>Qgis-user at lists.osgeo.org
>http://lists.osgeo.org/mailman/listinfo/qgis-user
Diese Nachricht wurde von meinem Android-Mobiltelefon mit K-9 Mail gesendet.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20130612/3c7e7e5e/attachment.html>
