[Qgis-user] qgis 2.0 does not respect labels' scale-based visibility option when opening existing 1.9 projects
Duarte Carreira
DCarreira at edia.pt
Thu Jun 13 04:15:54 PDT 2013
I created ticket: http://hub.qgis.org/issues/8052.
Thanks,
Duarte
De: Andreas Neumann [mailto:a.neumann at carto.net]
Enviada: quarta-feira, 12 de Junho de 2013 08:58
Para: Giovanni Manghi; qgis-user at lists.osgeo.org
Assunto: Re: [Qgis-user] qgis 2.0 does not respect labels' scale-based visibility option when opening existing 1.9 projects
I can confirm this issue. The min/max scales are set but disabled because the checkbox is turned off.
It is a migration issue of old projects.
Did you submit a bug?
Andreas
Giovanni Manghi <giovanni.manghi at faunalia.pt<mailto:giovanni.manghi at faunalia.pt>> schrieb:
Hi Duarte,
Can someone confirm? What I'm seeing is QGIS not turning on this option, but still maintaining the scale range values. It should open the project and keep the scale-based visibility option turned on
it seems to work fine with new projects, maybe there is something
wrong with projects created before the labeling overhaul of the last
weeks. Can you confirm?
cheers
-- Giovanni --
Qgis-user mailing list
Qgis-user at lists.osgeo.org<mailto:Qgis-user at lists.osgeo.org>
http://lists.osgeo.org/mailman/listinfo/qgis-user
Diese Nachricht wurde von meinem Android-Mobiltelefon mit K-9 Mail gesendet.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20130613/c639ad38/attachment.html>
