[Qgis-user] QGIS with SAGA in macos
William Kyngesburye woklist at kyngchaos.com
Thu Jun 13 06:50:56 PDT 2013
SAGA 2.0 is a problem.  To build SAGA 64bit on OS X a 64bit wxWidgets is needed.  To build wxWidgets 64bit, wx 2.9 is needed.  SAGA 2.0 doesn't support wx 2.9, but 2.1 does.
SAGA 2.1 does have a RC release (though strangely windows binary only, gotta get source from SVN).  Should be good enough?  I really want to have everything 64bit for QGIS, but at least Sextante executes external commands so SAGA will work 32bit is absolutely necessary.
On Jun 13, 2013, at 6:26 AM, Victor Olaya wrote:
>> An error has occured while executing Python code:
>> Traceback (most recent call last):
>>  File
>> "/Applications/QGIS_2.0-dev.app/Contents/MacOS/../Resources/python/plugins/sextante/gui/OutputSelectionPanel.py",
>> line 92, in saveToFile
>>    filename= unicode(files.first())
>> AttributeError: 'list' object has no attribute 'first'
> That error was fixed a few days ago in this commit
> https://github.com/qgis/Quantum-GIS/commit/a6f9f563095d2ebd3334de3809bda1d2f8ec1d64
> updating your qgis-dev version should fix it.
> The other problem is related to using 2.1.
> It's easy to update SEXTANTE for the export command (which is the one
> failing), but I do not want to do it until a final stable 2.1 is
> released. For now, SEXTANTE runs on the latest stable version of SAGA,
> ,which is 2.0.8
> Cheers
> Qgis-user mailing list
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
First Pogril: Why is life like sticking your head in a bucket filled with hyena offal?
Second Pogril: I don't know.  Why IS life like sticking your head in a bucket filled with hyena offal?
First Pogril: I don't know either.  Wretched, isn't it?
-HitchHiker's Guide to the Galaxy
