[Qgis-user] QGIS with SAGA in macos
William Kyngesburye
woklist at kyngchaos.com
Thu Jun 13 07:11:43 PDT 2013
There is one case where wxpython 2.9 (32 or 64bit) may be required: if you need to compile wxwidgets (instead of using a binary) on OS X 10.8+. wx 2.9 is needed for cocoa APIs on recent OS X versions, which means SAGA 2.1 is neeeded.
On Jun 13, 2013, at 8:50 AM, William Kyngesburye wrote:
> SAGA 2.0 is a problem. To build SAGA 64bit on OS X a 64bit wxWidgets is needed. To build wxWidgets 64bit, wx 2.9 is needed. SAGA 2.0 doesn't support wx 2.9, but 2.1 does.
> SAGA 2.1 does have a RC release (though strangely windows binary only, gotta get source from SVN). Should be good enough? I really want to have everything 64bit for QGIS, but at least Sextante executes external commands so SAGA will work 32bit is absolutely necessary.
> On Jun 13, 2013, at 6:26 AM, Victor Olaya wrote:
>>> An error has occured while executing Python code:
>>> Traceback (most recent call last):
>>> File
>>> "/Applications/QGIS_2.0-dev.app/Contents/MacOS/../Resources/python/plugins/sextante/gui/OutputSelectionPanel.py",
>>> line 92, in saveToFile
>>> filename= unicode(files.first())
>>> AttributeError: 'list' object has no attribute 'first'
>> That error was fixed a few days ago in this commit
>> https://github.com/qgis/Quantum-GIS/commit/a6f9f563095d2ebd3334de3809bda1d2f8ec1d64
>> updating your qgis-dev version should fix it.
>> The other problem is related to using 2.1.
>> It's easy to update SEXTANTE for the export command (which is the one
>> failing), but I do not want to do it until a final stable 2.1 is
>> released. For now, SEXTANTE runs on the latest stable version of SAGA,
>> ,which is 2.0.8
>> Cheers
>> Qgis-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
> William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
> http://www.kyngchaos.com/
> First Pogril: Why is life like sticking your head in a bucket filled with hyena offal?
> Second Pogril: I don't know. Why IS life like sticking your head in a bucket filled with hyena offal?
> First Pogril: I don't know either. Wretched, isn't it?
> -HitchHiker's Guide to the Galaxy
