[Qgis-user] Read GML geometry
Antonio Locandro antoniolocandro at hotmail.com
Wed Jun 19 08:11:47 PDT 2013
Thanks for the info
I will try to run GDAL 1.10 on windows and see if I can change the GML to another format
Regards
Ing. Antonio Locandro
Tegucigalpa, Honduras
Need a GPS map for Central America, Asia or South America / Necesitas un mapa GPS para Centro America, Asia o Sur America
> From: even.rouault at mines-paris.org
> To: qgis-user at lists.osgeo.org
> Subject: Re: [Qgis-user] Read GML geometry
> Date: Wed, 19 Jun 2013 00:58:42 +0200
> CC: antoniolocandro at hotmail.com
> Le lundi 17 juin 2013 17:40:42, AntonioLocandro a écrit :
> > I have a GML file for aeronautical data (its a polygon). When I load in
> > QGIS I can see the attribute data fine when I open the attribute table but
> > I can't see the geometry. What could the issue be? here is the xml file
> > https://docs.google.com/file/d/0B2WxCPuMM8hEb2p6dEoxaHNVVjg/edit?usp=shari
> > ng
> I've confirmed that the geometry is read since GDAL 1.10 (was returned as empty
> geometry in previous versions)
> When there will be a QGIS build available with GDAL 1.10, you will see the
> polygon. Otherwise you can download GDAL 1.10 and convert the GML into another
> format with ogr2ogr, so as to be able to open it in QGIS.
> Geospatial professional services
> http://even.rouault.free.fr/services.html
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20130619/e9a2a696/attachment.html>
