[Qgis-user] Fetch plugins missing
Borys Jurgiel
lists at borysjurgiel.pl
Wed Jun 26 12:18:16 PDT 2013
AFAIK the plugin installer is in python-qgis-common package rather than
python-qgis. You should install both (if available in the repository).
If it's installed and you still can't see it, it can be disabled in the plugin
manager. Go to Plugins -> Manage plugin and make sure the Plugin Installer
plugin is enabled.
B.
Dnia środa, 26 czerwca 2013 o 18:01:18 Julie Pierson napisał(a):
> Hi list,
> I uninstalled qgis 1.9 to switch back to qgis 1.8, and 'fetch plugins'
> has gone missing from the extension menu. I use ubuntu 13.04.
> I did install python-qgis. I installed qgis from the ubuntu-unstable
> repository.
> Do you have an idea on what may be causing this problem? I tried
> uninstalling and reinstalling qgis, to no avail. I wonder if it's do
> with python, since the python console is present in the extension menu,
> but doesn't show when I click on it.
> Thanks a lot for your help,
> Julie.
