[Qgis-user] Fetch plugins missing
Julie Pierson j.pierson at ades.cnrs.fr
Thu Jun 27 05:16:07 PDT 2013
Thank you for your answer. python-qgis-common is installed, and I
activated all the plugins in the plugin manager, still no plugin
installer. Am I missing something else?
Thanks,
Julie.
Le 26/06/2013 21:18, Borys Jurgiel a écrit :
> AFAIK the plugin installer is in python-qgis-common package rather than
> python-qgis. You should install both (if available in the repository).
> If it's installed and you still can't see it, it can be disabled in the plugin
> manager. Go to Plugins -> Manage plugin and make sure the Plugin Installer
> plugin is enabled.
> B.
> Dnia środa, 26 czerwca 2013 o 18:01:18 Julie Pierson napisał(a):
>> Hi list,
>> I uninstalled qgis 1.9 to switch back to qgis 1.8, and 'fetch plugins'
>> has gone missing from the extension menu. I use ubuntu 13.04.
>> I did install python-qgis. I installed qgis from the ubuntu-unstable
>> repository.
>> Do you have an idea on what may be causing this problem? I tried
>> uninstalling and reinstalling qgis, to no avail. I wonder if it's do
>> with python, since the python console is present in the extension menu,
>> but doesn't show when I click on it.
>> Thanks a lot for your help,
>> Julie.
