[Qgis-user] Fetch plugins missing
Julie Pierson j.pierson at ades.cnrs.fr
Fri Jun 28 04:51:37 PDT 2013
The log console reported an error when QGIS is launched :
"cannot load library /usr/lib/qgispython : (libqgispython.so: Cannot
open shared object file: No such file or directory)"
I did have libqgispython.so.1.8.0 in /usr/lib, so I tried renaming it to
just libqgispython.so.
Now I have another error message :
"cannot load library /usr/lib/qgispython : (libpython2.6.so.1.0: Cannot
It's strange because I use Python 2.7 and not Python 2.6... There seems
to be some confusion here. I will try to investigate further, I'll be
glad for your help if you have any other idea.
Thanks,
Julie.
Le 27/06/2013 19:15, Borys Jurgiel a écrit :
> So seems the installer is on board. Could you please take a look at the log
> console as well (The "!" icon in lower-right corner or in
> Settings->Panels->Log messages menu)? In the Plugins tab you should see just
> "Loaded Plugin Installer (package: plugin_installer)" message.
> If everything there is ok, probaby the error you reported may have something
> to do with it... It shows a problem with addidng a menu entry, however, it
> looks rather like the "Project properties" entry is going to be inserted
> twice. I never met such problem anyway and I'm afraid I have no idea what is
> the reason.
> You can also try to clear the configuration, by removing (or temorarily
> renaming the two directories: ~/.qgis and ~/.config/QuantumGIS
