[Qgis-user] How to get the UTM coordinates in my attribut table after projected a point filefrom geographics coordinates to UTM
Alexandre Neto
senhor.neto at gmail.com
Mon Mar 18 08:29:11 PDT 2013
If you are not in grass mood:
- Open layer attribute table;
- Start editing;
- Open field calculator;
- Create new field "coordX", with integer or decimal number, in expression
put $x and press ok;
- repeat the same for "coordY" with $y in the expression;
Done!
Alexandre Neto
2013/3/18 G. Allegri <giohappy at gmail.com>
> Risposta corretta, e visto che ci siamo lo dico anche in italiano :)
> giovanni
> 2013/3/18 Lene Fischer <lfi at life.ku.dk>
>> Ja det er den rigtige fremgangsmåde.
>> Med venlig hilsen
>> Lene Fischer
>> *Fra:* qgis-user-bounces at lists.osgeo.org [
>> qgis-user-bounces at lists.osgeo.org] på vegne af Alfonso Flaquer [
>> alfonsofla220 at gmail.com]
>> *Sendt:* 18. marts 2013 15:29
>> *Til:* Manuel Spínola
>> *Cc:* qgis-user
>> *Emne:* Re: [Qgis-user] How to get the UTM coordinates in my attribut
>> Una forma de hacerlo utilizando las funciones de grass es primero
>> agregar 2 columnas a la tabla con la función "addcol" (una columna para la
>> coordenada X y otra para la Y). Luego con la función v.to.db agregas las
>> coordenadas a las columnas creadas.
>> Saludos.
>> AfLa
>> El 18-03-2013, a las 9:16, Manuel Spínola <mspinola10 at gmail.com>
>> escribió:
>> Dear list members,
>> I projected a point file from geographics coordinates to UTM. How can
>> I get the UTM coordinates in the attribute table?
>> Best,
>> Manuel
>> *Manuel Spínola, Ph.D.*
>> Instituto Internacional en Conservación y Manejo de Vida Silvestre
>> Universidad Nacional
>> Apartado 1350-3000
>> Heredia
>> COSTA RICA
>> mspinola at una.ac.cr
>> Teléfono: (506) 2277-3598
>> Fax: (506) 2237-7036
>> Personal website: Lobito de río<https://sites.google.com/site/lobitoderio/>
>> Institutional website: ICOMVIS <http://www.icomvis.una.ac.cr/>
>> Qgis-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
> Giovanni Allegri
> website: http://giovanniallegri.it
> GEO+ geomatica in Italia http://bit.ly/GEOplus
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20130318/2634080f/attachment.html>
