[Qgis-user] How to get the UTM coordinates in my attribut table after projected a point filefrom geographics coordinates to UTM
Andre Joost
andre+joost at nurfuerspam.de
Mon Mar 18 08:41:02 PDT 2013
Am 18.03.2013 14:16, schrieb Manuel Spínola:
> Dear list members,
> I projected a point file from geographics coordinates to UTM. How can I
> get the UTM coordinates in the attribute table?
Not sure what was suggested in Spanish, but I use the field calculator
in the attribute table for such things:
Change to edit mode
Start Field calculator
Give E or X as new field name
Field Type should be set to real
accuracy to 1 (or more for degrees)
under "Geometry", select $x entry
OK
Same for $y values.
After Saving, the values get rounded to the accuracy you gave.
HTH,
André Joost
